[swak4Foam] groovy bc, conditioned valueExpression. |
March 16, 2015, 03:48 |
Kan
Rep Power: 12 |
Dear OpenFOAMer,
I am currently using groovyBC to set my thermal boundary condition, the flow regime is determined based on Reynolds number Re, which is calculated in the "variables", and three different heat transfer coefficients ( hf0, hf1, hf2 ) corresponding to laminar, transition and turbulent are also calculated with "variables". The condition is something like Code:
if ( Re< 2000 ) hf0; else if ( Re > 4000 ) hf2; else hf1; Here is the example I found: Code:
valueExpression "(pos().z<=A*cos(-w*time())+0.5*k*A*A*cos(2*(-w*time()))) ? 1 : 0"; Cheers, Kan |
March 16, 2015, 08:47 |
Joachim Herb
Rep Power: 21 |
You could try something like
valueExpression "Re <= 2000 ? hf0 : (Re <= 4000 ? hf1 : hf2)"; |
March 16, 2015, 17:30 |
Kan
Rep Power: 12 |
[swak4Foam] Engine-pressure BC and velocity field (groovy) | Tobi | OpenFOAM Community Contributions | 3 | October 15, 2018 14:09 |
[swak4Foam] groovy BC | imani | OpenFOAM Community Contributions | 1 | April 13, 2014 07:43 |
[swak4Foam] groovy BC | Ahmed Khattab | OpenFOAM Community Contributions | 4 | November 7, 2013 07:51 |
[swak4Foam] groovyBC: using gradientExpression instead of valueExpression | gregdB | OpenFOAM Community Contributions | 15 | September 20, 2013 08:03 |
[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions) | Tobi | OpenFOAM Community Contributions | 0 | May 23, 2013 14:53 |
