[waves2Foam] Couple waves2foam with dynamic mesh |
April 4, 2014, 08:25 |
Paritosh Vasava
Rep Power: 22 |
I have openFoam 2.2 installed and the waves2foam directory is on my desktop. I have manged to compile the waves2foam toolbox and also ran few tutorials without without any problem.
Now, I am trying to couple waves2foam with dynamic mesh with instructions given in these two links. http://openfoamwiki.net/index.php/Co...dify_interFoam https://sites.google.com/site/jordim...ic-mesh-motion Here are steps that I followed: 1. Copy interDyMFoam to waveFoam directory. 2. The interDyMFoam had only correctPhi.H, pEqn.H and readControls.H files. Therefore I copied rest of the files alphaCourantNo.H, alphaEqn.H, alphaEqnSubCycle.H, setDeltaT.H, Ueqn.H from the waveFoam solver folder. 3. Also I copied the createFields.H from the interFoam directory in the OpenFoam2.2 directory. 4. I renamed the solver and respective files as 'waveDyMFoam'. 5. I made modifications as suggested in these webpages. 6. Then I ran the Allwmake file and got the following error (in the waves2foam.log file). Now I assume that the other solvers were compiled properly compiled but the waveDyMFoam did not compile properly. Could someone please help me correct this. Here is the error log file. Last edited by wyldckat; November 4, 2018 at 13:47. Reason: merged posts a minute apart |
April 7, 2014, 13:43 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good evening,
@Vasava and other interDyMFoam+waves2Foam users: The guide on how to create both waveFoam and waveDyMFoam on the wiki is outdated (as is also explicitly stated). Furthermore, it is a deliberate choice not to distribute waves2Foam with a waveDyMFoam solver, since my experience with this type of solver is somewhat limited. Therefore, if someone is willing to create the waveDyMFoam solver (preferably for all OF-versions supported through waves2Foam) and make them available through the svn-repositories along with one or more tutorials, I would gladly receive the contribution. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; November 4, 2018 at 13:47. Reason: removed answer to another post that was on the main thread |
April 8, 2014, 01:17 |
Paritosh Vasava
Rep Power: 22 |
Thanks for the response Niels. I hope someone comes up with a solution.
How To: couple waves2Foam with dynamic mesh motion | armangh | OpenFOAM | 0 | June 29, 2016 12:02 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
