[waves2Foam] 3DWaves case: Unknown patchField type waveVelocity
Old   March 31, 2014, 04:12
Default 3DWaves case: Unknown patchField type waveVelocity
Paritosh Vasava
vasava will become famous soon enough
I have openFoam 2.2 and I added the wave2Foam toolbox to it. I have this toolbox folder on my desktop and could compile it without any problem.
But when I try to run the 3Dwaves tutorial I get the following error:
Unknown patchField type waveVelocity for patch type patch
Valid patchField types are :
67
SRFFreestreamVelocity
SRFVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalSlip
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
nonuniformTransformCyclic
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentInlet
uniformFixedValue
uniformJump
uniformJumpAMI
variableHeightFlowRateInletVelocity
waveTransmissive
wedge
zeroGradient
file: /home/paritosh/Desktop/currentWork/waveTests/3Dwaves/0/U.boundaryField.inlet0 from line 26 to line 30.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 136.
FOAM exiting
I doubt that this error is due to the fact that the toolbox folder is on my desktop and not with openfoam directory. But I would like to hear what you guys have to say about it.
So any help or suggestion?
vasava is offline   Reply With Quote
Old   March 31, 2014, 06:31
Paritosh Vasava
Originally Posted by vasava View Post
........I doubt that this error is due to the fact that the toolbox folder is on my desktop and not with openfoam directory.
I could fix the issue by correcting the waveProperties file.
Old   March 31, 2014, 14:18
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Paritosh and others,
I cannot reproduce the error, as I have been able to execute the 3Dwaves tutorial straight out of the box on OF2.2.
I used a check-out of revision 2040.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 1, 2014, 07:40
Paritosh Vasava
Kind regards,
Niels
Do you mean the toolbox comes with openfoam 2.2 (and later versions)??
Old   April 1, 2014, 14:54
ngj
No, I mean that by using the most recent svn revision of waves2Foam, I cannot reproduce the error.
waves2Foam is a plugin to OpenFoam, and I try to keep it up to date with new versions, but it is not natively distributed with neither OpenFoam nor the foam-extend project.
Kind regards,
Niels
Old   April 2, 2014, 02:53
Paritosh Vasava
Ok, I got it now. I simply misunderstood your sentence and started looking for the wave2Foam in openFoam folders. Silly me!!
Old   October 28, 2021, 23:09
Anthony Moris Danve
Anthony Danv is on a distinguished road
I also faced the same trouble for "Unknown patchField type waveVelocity". May you help me fix it?. Thanks
Anthony Danv is offline   Reply With Quote
Old   November 1, 2021, 12:50
ngj
Hi Anthony,
You need to provide a lot more information to expect qualified help.
Kind regards
Niels
Old   January 18, 2022, 09:32
Tony Zhang
zyfsoton is on a distinguished road
Hi, I have had the same problem recently.
I copied the DTCHullWave tutorial case into my own directory then I replaced the STL file and then did my own blockMesh, refineMesh and snappyHexMesh etc. Then I did renumberMesh, the error reported:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/OpenFOAM/OpenFOAM-7/run/KCSDRIFTINWAVE/0/U.boundaryField.inlet from line 31 to line 31.
Then I had to add value in alpha.water and U files in 0 folder (value $internalField; in both inlet BCs in both files)
Then setWaves and decomposePar ran smoothly without any error.
Finally, running interFoam, error reads: Unknown patchField type waveVelocity for patch type patch; (/0/U.boundaryField.inlet)
I think the same error will reported in 0/alpha.water.inlet as well for Unknown patchField type waveAlpha for patch type patch;
Please let me know if you have any hint to resolve this issue! Many thanks and Btw I am using OF version 7 and the patches of waveAlpha and waveVelocity should have been included in OFv7, and I can run DTCHullWave tutorial case without any error!
Any help will be appreciated!
Tony
zyfsoton is offline   Reply With Quote
Old   January 18, 2022, 12:27
Tony Zhang
Hi Anthony,
Kind regards
Niels
Hi Niels,
Please see my post above, any help will be appreciated!
Many thanks,
Tony
Old   January 18, 2022, 13:48
ngj
Hi Tony,
The way you describe the workflow, you rely on the wave models in OpenFoam 7 or olaFlow. Neither of these are related to waves2Foam, so I can only recommend that you direct your question to a suitable thread.
Kind regards
Niels
Old   January 18, 2022, 14:07
Tony Zhang
Hi Tony,
Kind regards
Niels
Dear Niels,
Thank you for your quick reply!
As mentioned before, I am using OF to simulate ships in waves. Is waves2Foam compatible within OpenFOAMv7? I am thinking to use waves2Foam for wave generation instead of OF own one now.
Many thanks,
Tony
wallHeatFlux utility for an incompressible case Mr.Jingles OpenFOAM Post-Processing 62 December 22, 2018 12:07
Inlet patch problems martyn88 OpenFOAM Running, Solving & CFD 6 April 21, 2017 19:34
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 07:00
SimpleFoam - instable simulation Specialist OpenFOAM Running, Solving & CFD 17 August 12, 2014 05:52
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
