[waves2Foam] the Stream Function theory with different A() and B() |
November 19, 2018, 05:20 |
Rep Power: 9 |
Hi all,
I meet with a problem in waves2Foam, I want to use stream Function, with known A coefficient and B coefficient. However, A coefficient has different number from B coefficient, so how can I adjust the value of N in waveProperties? Looking forward for reply, thanks a lot. |
November 21, 2018, 00:48 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi May,
The code is not built for different number of coefficients for A and B, since you are then prescribing an inconsistency between surface elevation and velocity field. If you really want to do this, I suggest that you think up some kind of hack. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
