[swak4Foam] problem with compiling when WM_LABEL_SIZE is set to 64
Like Tree2Likes
  • 2 Post By Daniel_Khazaei
Old   January 21, 2019, 03:52
Default problem with compiling when WM_LABEL_SIZE is set to 64
Daniel
Daniel_Khazaei will become famous soon enough
Dear foamers,
I have a problem when compiling swak4Foam in conjunction with an OpenFOAM or foam-extend compiled with WM_LABEL_SIZE set to 64! The process fails at exactly the same line of "swakShiftFieldFunctionPlugin" on both foam-extend-4.1 (nextRelease) and OpenFOAM-v1812.
However, there is no problem when WM_LABEL_SIZE is set to 32.
OpenFOAM plus v1812
wmake libso swakShiftFieldFunctionPlugin
g++-8 -std=c++11 -m64 -DOPENFOAM=1812 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100       -I../../swak4FoamParsers/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/sampling/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/surfMesh/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/lagrangian/basic/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/meshTools/lnInclude -IlnInclude -I. -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude -I/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OSspecific/POSIX/lnInclude   -fPIC -c shiftFieldGeneralPluginFunction.C -o Make/linux64GccDPInt64Opt/shiftFieldGeneralPluginFunction.o
In file included from ../../swak4FoamParsers/lnInclude/ExpressionResult.H:321,
                 from ../../swak4FoamParsers/lnInclude/CommonPluginFunction.H:50,
                 from ../../swak4FoamParsers/lnInclude/ConcretePluginFunction.H:43,
                 from ../../swak4FoamParsers/lnInclude/FieldValuePluginFunction.H:43,
                 from shiftFieldGeneralPluginFunction.H:43,
                 from shiftFieldGeneralPluginFunction.C:34:
../../swak4FoamParsers/lnInclude/ExpressionResultI.H: In member function ‘void Foam::ExpressionResult::setSingleValueInternal(Type)’:
../../swak4FoamParsers/lnInclude/ExpressionResultI.H:229:13: warning: unnecessary parentheses in declaration of ‘single_’ [-Wparentheses]
         Type(single_)=val;
In file included from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/List.H:381,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/labelList.H:60,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/UPstream.H:42,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from ../../swak4FoamParsers/lnInclude/DebugOStream.H:50,
                 from ../../swak4FoamParsers/lnInclude/swak.H:596,
                 from shiftFieldGeneralPluginFunction.C:33:
/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/List.C: In instantiation of ‘Foam::List<T>::List(InputIterator, InputIterator) [with InputIterator = long int; T = Foam::polyPatch*]’:
shiftFieldGeneralPluginFunction.C:96:26:   required from ‘void Foam::shiftFieldGeneralPluginFunction<Type, Order>::doEvaluation() [with Type = double; Foam::meshToMesh::interpolationMethod Order = (Foam::meshToMesh::interpolationMethod)3]’
shiftFieldGeneralPluginFunction.C:227:7:   required from here
/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/List.C:300:44: error: no matching function for call to ‘distance(long int&, long int&)’
     List<T>(begIter, endIter, std::distance(begIter, endIter))
In file included from /usr/include/c++/8/bits/stl_algobase.h:66,
                 from /usr/include/c++/8/bits/char_traits.h:39,
                 from /usr/include/c++/8/string:40,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/string.H:52,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/word.H:43,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/int16.H:39,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/int.H:38,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/label.H:39,
                 from /home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/labelList.H:59,
/usr/include/c++/8/bits/stl_iterator_base_funcs.h:138:5: note: candidate: ‘template<class _InputIterator> typename std::iterator_traits<_Iterator>::difference_type std::distance(_InputIterator, _InputIterator)’
     distance(_InputIterator __first, _InputIterator __last)
/usr/include/c++/8/bits/stl_iterator_base_funcs.h:138:5: note:   template argument deduction/substitution failed:
/usr/include/c++/8/bits/stl_iterator_base_funcs.h: In substitution of ‘template<class _InputIterator> typename std::iterator_traits<_Iterator>::difference_type std::distance(_InputIterator, _InputIterator) [with _InputIterator = long int]’:
/home/shadowfax/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/List.C:300:44:   required from ‘Foam::List<T>::List(InputIterator, InputIterator) [with InputIterator = long int; T = Foam::polyPatch*]’
/usr/include/c++/8/bits/stl_iterator_base_funcs.h:138:5: error: no type named ‘difference_type’ in ‘struct std::iterator_traits<long int>’
make: *** [/home/shadowfax/OpenFOAM/OpenFOAM-v1812/wmake/rules/General/transform:35: Make/linux64GccDPInt64Opt/shiftFieldGeneralPluginFunction.o] Error 1
Making dependency list for source file shiftFieldGeneralPluginFunction.C
could not open file interpolation2DTable.H for source file shiftFieldGeneralPluginFunction.C
could not open file string.H for source file shiftFieldGeneralPluginFunction.C
could not open file mappedFvPatch.H for source file shiftFieldGeneralPluginFunction.C
could not open file mappedWallFvPatch.H for source file shiftFieldGeneralPluginFunction.C
could not open file mappedPointPatch.H for source file shiftFieldGeneralPluginFunction.C
SOURCE=shiftFieldGeneralPluginFunction.C ;  g++-8 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -Wno-class-memaccess -O3  -DNoRepository -ftemplate-depth-200 -DFOAM_DEV         -I../../swak4FoamParsers/lnInclude     -I/home/shadowfax/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/shadowfax/foam/foam-extend-4.1/src/sampling/lnInclude     -I/home/shadowfax/foam/foam-extend-4.1/src/surfMesh/lnInclude     -I/home/shadowfax/foam/foam-extend-4.1/src/lagrangian/basic/lnInclude     -I/home/shadowfax/foam/foam-extend-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude -I/home/shadowfax/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/shiftFieldGeneralPluginFunction.o
         Type(single_)=val;
In file included from /home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude/List.H:297,
                 from /home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude/labelList.H:36,
                 from /home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude/Pstream.H:43,
/home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude/List.C: In instantiation of ‘Foam::List<T>::List(InputIterator, InputIterator) [with InputIterator = long int; T = Foam::polyPatch*]’:
shiftFieldGeneralPluginFunction.C:96:26:   required from ‘void Foam::shiftFieldGeneralPluginFunction<Type, Order>::doEvaluation() [with Type = double; Foam::meshToMesh::order Order = (Foam::meshToMesh::order)1]’
/home/shadowfax/foam/foam-extend-4.1/src/foam/lnInclude/List.C:207:37: error: ‘iter’ cannot be used as a function
         this->operator[](s++) = iter();
make: *** [shiftFieldGeneralPluginFunction.dep:667: Make/linux64GccDPOpt/shiftFieldGeneralPluginFunction.o] Error 1
Regards,
D. Khazaei
Daniel_Khazaei is offline   Reply With Quote
Old   January 21, 2019, 05:25
Daniel
fixed on both foam-extend-4.1 and OpenFOAM-v1812 by applying the suggested fix from here:
https://sourceforge.net/p/foam-extend/tickets/21/
List<polyPatch*> newBound(origBound.size(), NULL);
to
List<polyPatch*> newBound(origBound.size(), static_cast<polyPatch*>(NULL));
wyldckat and arashn18 like this.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Compile problem ccm26ToFoam in OpenFoam-1.6 shildenbrand OpenFOAM Bugs 11 October 20, 2009 16:43
fortran compile problem Don CFX 1 November 5, 2008 06:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
