[RapidCFD] Encountered a new error that I have no idea how to fix |
Rep Power: 8 ![]() |
Hello everyone,
while running a simulation I came across an error that I do not know what it means at all. Can anyone point me to the right direction? The simulation is a simple square prism with water inside. The tank is set to oscillate left and right to simulate sloshing. The idea is to study how fluid behaves while sloshing. However I came across this error before the simulation can start. /*---------------------------------------------------------------------------*\ | RapidCFD by simFlow (sim-flow.com) | \*---------------------------------------------------------------------------*/ Build : dev-f3775ac96129 Exec : interDyMFoam Date : May 21 2019 Time : 09:50:48 Host : "1070-test" PID : 14552 Case : /root/SSH/sloshing3/sloshing3/sloshing3 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementLaplacian --> FOAM FATAL IO ERROR: unexpected class name vectorField expected vectorgpuField while reading object points file: /root/SSH/sloshing3/sloshing3/sloshing3/constant/polyMesh/points at line 17. --> FOAM Warning : From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 136. FOAM exiting |
another problem I am having is that I seem to be having an issue running simulations with multiple GPUs. Below lies my error that I am encountering.
Those simulation runs fine in series, however I am having issues running things parallel. --> FOAM Warning : From function Time: ![]() in file db/Time/Time.C at line 1055 Increased the timePrecision from 7 to 8 to distinguish between timeNames at time 0.2415173 MULES: Solving for alpha.Water MULES: Solving for alpha.Water Phase-1 volume fraction = 0.408125 Min(alpha1) = -1.459455e-06 Max(alpha1) = 1.000014 --> FOAM Warning : From function Time: ![]() in file db/Time/Time.C at line 1055 Increased the timePrecision from 8 to 10 to distinguish between timeNames at time 0.2415173 MULES: Solving for alpha.Water MULES: Solving for alpha.Water Phase-1 volume fraction = 0.408125 Min(alpha1) = -1.193857e-06 Max(alpha1) = 1.000027 --> FOAM Warning : From function Time: ![]() in file db/Time/Time.C at line 1055 Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 0.2415173 [0] [1] #0 Foam::error: ![]() ![]() [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 at ??:? [1] #2 in "/lib64/libc.so.6" [1] #3 Foam::PBiCG::solve(Foam::gpuField<double>&, Foam::gpuField<double> const&, unsigned char) const in "/lib64/libc.so.6" [0] #3 Foam::PBiCG::solve(Foam::gpuField<double>&, Foam::gpuField<double> const&, unsigned char) const at ??:? [1] #4 at ??:? [0] #4 [0] at ??:? [0] #5 [1] at ??:? [1] #5 [0] at ??:? [0] #6 [1] at ??:? [1] #6 [1] at ??:? [1] #7 [0] at ??:? [0] #7 [1] at ??:? [1] #8 __libc_start_main[0] at ??:? [0] #8 __libc_start_main in "/lib64/libc.so.6" [1] #9 in "/lib64/libc.so.6" [0] #9 [1] at ??:? [1070-test:02056] *** Process received signal *** [1070-test:02056] Signal: Floating point exception (8) [1070-test:02056] Signal code: (-6) [1070-test:02056] Failing at address: 0x808 [0] at ??:? [1070-test:02055] *** Process received signal *** [1070-test:02055] Signal: Floating point exception (8) [1070-test:02055] Signal code: (-6) [1070-test:02055] Failing at address: 0x807 [1070-test:02055] [ 0] /lib64/libc.so.6(+0x36280)[0x7f44a339f280] [1070-test:02055] [ 1] [1070-test:02056] [ 0] /lib64/libc.so.6(+0x36280)[0x7f5834b7c280] [1070-test:02056] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f5834b7c207] [1070-test:02056] [ 2] /lib64/libc.so.6(+0x36280)[0x7f5834b7c280] [1070-test:02056] [ 3] /root/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_8gpuField IdEERKS2_h+0x65c)[0x7f58361941cc] [1070-test:02056] [ 4] interFoam[0x508a9e] [1070-test:02056] [ 5] interFoam[0x533e07] [1070-test:02056] [ 6] interFoam[0x534088] [1070-test:02056] [ 7] interFoam[0x4777bf] [1070-test:02056] [ 8] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f5834b683d5] [1070-test:02056] [ 9] interFoam[0x47ac6b] [1070-test:02056] *** End of error message *** /lib64/libc.so.6(gsignal+0x37)[0x7f44a339f207] [1070-test:02055] [ 2] /lib64/libc.so.6(+0x36280)[0x7f44a339f280] [1070-test:02055] [ 3] /root/RapidCFD/RapidCFD-dev/platforms/linux64NvccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_8gpuField IdEERKS2_h+0x65c)[0x7f44a49b71cc] [1070-test:02055] [ 4] interFoam[0x508a9e] [1070-test:02055] [ 5] interFoam[0x533e07] [1070-test:02055] [ 6] interFoam[0x534088] [1070-test:02055] [ 7] interFoam[0x4777bf] [1070-test:02055] [ 8] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f44a338b3d5] [1070-test:02055] [ 9] interFoam[0x47ac6b] [1070-test:02055] *** End of error message *** -------------------------------------------------------------------------- mpiexec noticed that process rank 1 with PID 2056 on node 1070-test exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
Display Modes | |
new idea , lets discuss it together | afghani | Main CFD Forum | 3 | April 30, 2012 13:54 |
Search idea for solving a transient problem | tH3f0rC3 | OpenFOAM | 3 | May 13, 2011 16:01 |
Project idea.. | vinno | Main CFD Forum | 0 | October 3, 2010 17:53 |
How do I fix the temperature within a flow? | CarlosT | OpenFOAM | 0 | April 26, 2010 06:36 |
CFD project idea | John Cleveland | Main CFD Forum | 4 | March 8, 2005 13:55 |
