[waves2Foam] libgsl.so.0: cannot open shared object file: No such file or directory |
June 2, 2019, 15:21 |
Erdinc
Hi all,
I successfully compiled waves2foam and it works fine in tutorials. If I try to use mpi -np #core waveFoam -parallel command in cluster it also works fine. On the other hand, if I submit a job using qsub Job.sh command, I got the following error: "waveFoam: error while loading shared libraries: libgsl.so.0: cannot open shared object file: No such file or directory -------------------------------------------------------------------------- mpirun noticed that the job aborted, but has no info as to the process that caused that situation. --------------------------------------------------------------------------" Since it is a cluster I need to submit jobs using qsub command. I appreciate it if you could help me to solve the issue. |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 04:01 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
