Thomas Sprich
Rep Power: 7 ![]() |
Dear Foamers,
Is it possible to create baffles with cfMesh? I am trying to mesh zero thickness walls within the domain. Using surfaceMeshRefinement, it is possible to refine around the wall, but when I check the mesh with checkMesh, the wall has zero faces. I have tried playing with 'keepCellsIntersectingBoundary' and 'keepCellsIntersectingPatchs', but in all cases I get zero faces on the wall patch. In these slides, it seems that it is possible to create a baffle (see slide 4), but I can'e work it out. My meshDict is as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | _ _ _ _ | | | // \\ | Creative Fields cfMeshPRO | | | cfMeshPRO | | | | \\ _ _ _ _ // | Version: 0.0.99 | | | Web: www.c-fields.com e-mail: support@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // maxCellSize 0.025; surfaceFile "newGeo.fms"; surfaceMeshRefinement { baffle1 { surfaceFile "constant/triSurface/baffle1.stl"; additionalRefinementLevels 1; } } edgeMeshRefinement { baffle1 { edgeFile "baffle1.eMesh" additionalRefinementLevels 1; } } objectRefinements { refinement_for_surface { //cellSize 20.1; p0 ( -0 0 0.6 ); p1 ( -0 0 0.7 ); radius0 0.8; radius1 0.8; additionalRefinementLevels 1; type cone; } / } //keepCellsIntersectingBoundary 1; keepCellsIntersectingPatchs { baffle1 { keepCells 1; } } workflowControls { } // ************************************************************************* // Thomas |
Kmeti Rao
Rep Power: 4 ![]() |
Hi Thomas,
Did you manage to figure out creating baffles? It would be interesting to know if you have succeeded. Thank you Krao |
Thomas Sprich
Hi Krao,
Sadly not... Thomas |
Ben Gherardi
Rep Power: 6 ![]() |
Landed on this post while looking for how to do baffles in cfmesh, and then found out they had an example on their website using sails. In case someone else lands on this post seeking the same answer, here is the link to the downloadable examples (then click on the sails picture to get a .zip): https://cfmesh.com/download-examples/ Enjoy, Ben |
Display Modes | |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[DesignModeler] Create baffles | fluidstu | ANSYS Meshing & Geometry | 1 | May 30, 2016 00:47 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
