Krao |
August 13, 2019 11:07 |
reconstructPar error in MRFsimpleFoam (ami apprach) using GroovyBC velocity inlet
Hi Dear Foam users,
I am simulating propeller with MRFSimpleFoam using AMI. So far the simulation results and convergence are satisfactory and the forces are close to the analytical results.
I wanted to simulate a second propeller in the slipstream of the first propeller. Since changing MRF region size affected the results significantly, I was forced to simulate the two propellers separately. As I have to reproduce the slipstream of first propeller at the inlet of the second propeller, I have used groovyBC from swak4foam to generate the inlet swirl. Again the simulation went very well and the convergence of forces was great. But when I started to reconstruct the result to start these simulation with more powerful PC I got the following error
Reconstructing fields for mesh region0
Time = 0.02
Reconstructing FV fields
Reconstructing volScalarFields
p
nut
k
omega
Reconstructing volVectorFields
U
AMI: Creating addressing and weights between 3544 source faces and 4276 target faces
AMI: Patch source sum(weights) min/max/average = 0.883736, 1.0012, 0.99758
AMI: Patch target sum(weights) min/max/average = 0, 1.00088, 0.870331
AMI: Creating addressing and weights between 388 source faces and 3245 target faces
--> FOAM FATAL ERROR:
Unable to set source and target faces
From function void Foam::faceAreaWeightAMI<SourcePatch, TargetPatch>::setNextFaces(Foam::label&, Foam::label&, Foam::label&, const boolList&, Foam::labelList&, const Foam::DynamicList<int>&, bool) const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::label = int; Foam::boolList = Foam::List<bool>; Foam::labelList = Foam::List<int>]
in file lnInclude/faceAreaWeightAMI.C at line 292.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam: :face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calcAddressing(Foam::List<Foam::DynamicList<int , 0u, 2u, 1u> >&, Foam::List<Foam::DynamicList<double, 0u, 2u, 1u> >&, Foam::List<Foam::DynamicList<int, 0u, 2u, 1u> >&, Foam::List<Foam::DynamicList<double, 0u, 2u, 1u> >&, int, int) at ??:?
#3 Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam: :face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int) at ??:?
#4 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, bool) at ??:?
#5 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::constructFromSurface(Foam::PrimitivePatch<Foam: :face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&, bool) at ??:?
#6 Foam::cyclicAMIPolyPatch::resetAMI() const at ??:?
#7 Foam::cyclicAMIPolyPatch::AMIs() const at ??:?
#8 Foam::tmp<Foam::Field<double> > Foam::cyclicAMIPolyPatch::interpolate<double>(Foam ::Field<double> const&, Foam::UList<double> const&) const at ??:?
#9 Foam::cyclicAMIFvPatch::nbrDeltan() const at ??:?
#10 Foam::cyclicAMIFvPatch::makeWeights(Foam::Field<do uble>&) const at ??:?
#11 Foam::surfaceInterpolation::makeWeights() const at ??:?
#12 Foam::surfaceInterpolation::weights() const at ??:?
#13 Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:?
#14 Foam::surfaceInterpolation::deltaCoeffs() const at ??:?
#15 Foam::fvPatch::deltaCoeffs() const at ??:?
#16 Foam::groovyBCFvPatchField<Foam::Vector<double> >::groovyBCFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#17 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::groovyBCF vPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#18 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#19 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::Dimensio nedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#20 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#21 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#22 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#23 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#24 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#25 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#26 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#27 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
Aborted (core dumped)
As it can be clearly observed, as per my understanding the error is stating that the AMI weights are going to zero. But I have double checked during decomposition and solving the AMI weights are normal as shown below
AMI: Creating addressing and weights between 151942 source faces and 9229 target faces
AMI: Patch source sum(weights) min/max/average = 0.967284, 1.33993, 0.999878
AMI: Patch target sum(weights) min/max/average = 0.989309, 1.07397, 1.00007
AMI: Creating addressing and weights between 7129 source faces and 7521 target faces
AMI: Patch source sum(weights) min/max/average = 0.999682, 1.00121, 1
AMI: Patch target sum(weights) min/max/average = 0.984372, 1.00089, 0.999992
AMI: Creating addressing and weights between 18870 source faces and 19132 target faces
AMI: Patch source sum(weights) min/max/average = 0.999615, 1, 1
AMI: Patch target sum(weights) min/max/average = 0.9995, 1, 1
The error is occurring only during the simulation with groovyBC. In all other cases the simulation is running fine. Should I considering other decomposition approach than scotch? It would be very great if anyone can give me some useful insight to avoid these errors. Also, I would be open for other ideas as well regarding MRF region size also and how to overcome that difficulty also. Thank you in advance.
Krao
