[cfMesh] Interpreting console output during meshing
Old   August 16, 2019, 04:13
Default Interpreting console output during meshing
nope is on a distinguished road
Hello everyone
cfMesh is quite fast. But still, large meshes (>20M) still take more time than i'm willing to stare on the screen. This is especially noticable when trying to mesh a complex geometry and the meshing fails over and over.
If I could know during the meshing process that its not going well and will result in a bad mesh, i don't have to wait till the end. Unfortunately I couldn't find any information regarding the console output of cfMesh and maybe some opinions from experience.
Important thins to know would be something like:
  • If the number of inverted boundary faces does not go down to 0, what does that mean for the finished mesh? Is it still possible to get mesh with decent quality?
  • If a FOAM Serious Error appears, e.g. with negative volume sizes followed by the remark "This mesh is invalid", is it still worth to let it run till the end? Can this error be solved later on during the meshing process?
  • etc
Informations like this would be nice to see in the user guide: http://cfmesh.com/wp-content/uploads...VS8R8D5NTStPFF
Any information is appreciated and of value for all cfMesh users.
Regards, nope
nope is offline   Reply With Quote
Old   August 16, 2019, 20:59
Raul Ciria Aylagas
RaulCA is on a distinguished road
From my experience, if you have FOAM serious error, or a big number of inverted faces (>10.000) you will have a very bad mesh.
If the number of inverted faces is not going to zero but is not very big, you can work with that.
You can stop the meshing proccess after the edgeExtraction step to inspect the mesh and see if it is going well or if it has serious defects. With that you can skip smoothing procedure and save some time.
RaulCA is offline   Reply With Quote
cfmesh, console, experience, output
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
Extracting the output from the FLUENT console window kesari Fluent UDF and Scheme Programming 0 February 21, 2014 05:37
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
