[waves2Foam] significant wave height dissipation when using the k omega model for wave simultation |
June 17, 2018, 22:05 |
Maoyanjun
Rep Power: 10 |
Hello everyone:
I am using the waves2foam to generate Stokes II waves. But when I tried to use the k omega turbulence model or the k epsilon model, I got a significant dissipation of wave height. Is it normal or not? hope for your suggestions! -------------------------------- the wave condition is as follow: the length of the wave tank L =50m, the location of the Probes ProbeVOF1=5.0m away from the inlet; ProbeVOF2=10.0m; ProbeVOF3=20.0m; ProbeVOF4=30.0m; ProbeVOF5=49.0m; the wave height 0.5m;wave period T=2.4s,water depth h=10.0m ------------------------------------------ boundary conditions for k, $\omega$ and nut: k: ``` Code:
internalField uniform 0.001; boundaryField { #includeEtc "caseDicts/setConstraintTypes" inlet { type zeroGradient; //value uniform 0.001; // I have tried the fixedValue boundary, kqRWallFunction, also got similar results } outlet { type zeroGradient; //value uniform 0.001; // I have tried the fixedValue boundary, kqRWallFunction, also got similar results } bottom { type kqRWallFunction; value uniform 0.001; } frontBack { type empty; } atmosphere { type inletOutlet; inletValue uniform 0.001; value uniform 0.001; } omega: ``` Code:
boundaryField { inlet { type zeroGradient; //value $internalField; } outlet { type zeroGradient; //value $internalField; } bottom { type omegaWallFunction; value $internalField; } atmosphere { type inletOutlet; inletValue $internalField; value $internalField; } frontAndBack { type empty; } } nut: ``` Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" inlet { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } outlet { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } bottom { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } frontBack { type empty; } atmosphere { type calculated; value uniform 0; } ``` ___________________________ the surface elevation of this four probes: |
June 11, 2020, 10:47 |
Solution
Jente Vercammen
Rep Power: 6 |
Did you find a solution for the problem? I have the same problem? Kind regards Jente |
June 11, 2020, 13:56 |
Rep Power: 12 |
Heavy dissipation on free surface is a well known problem on VOF modeling techniques specially with kOmega based turbulence models. As a solution you can find and try stabilized versions of the turbulence models or you can try higher order models such LienCubic kEpsilon.
August 3, 2020, 22:21 |
#4 | |
Maoyanjun
Rep Power: 10 |
> Application of a buoyancy-modified k-ω SST turbulence model to simulate wave run-up around a monopile subjected to regular waves using OpenFOAM® these two papers have give an answer to this problem, but I have not tested them, hope for hearing more tests on these modefied turbulence models. |
October 7, 2020, 14:19 |
Rep Power: 11 |
I had experienced the same issue with OpenFOAM v1912 for the k-w sst model. The solution was to reduce the initial values of the KTE and omega, and to refine the mesh (smaller cells). This issue is mainly for structure-free regions. This is a known problem for incompressible VOF turbulence modelling and I could get the solution given here (fvOption) to work beyond a very short period of the onset of my simulations (https://www.openfoam.com/releases/op...nd-physics.php).
October 25, 2022, 08:43 |
Dissipation Control
irengclenk
Rep Power: 5 |
So far, the best solution I can suggest is using the dissipation control as introduced in Larsen, B., & Fuhrman, D. (2018). On the over-production of turbulence beneath surface waves in Reynolds-averaged Navier–Stokes models. Journal of Fluid Mechanics, 853, 419-460. doi:10.1017/jfm.2018.577. The code is avalaible in here: https://github.com/BjarkeEltardLarsen?tab=repositories
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 0 | December 24, 2011 09:10 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Eddy dissipation model | ioana | CFX | 1 | June 10, 2004 14:15 |
