[swak4Foam] Can't use grad(U) in a swakExpression! |
October 15, 2019, 15:27 |
Bernardo Ribeiro
Rep Power: 9 |
Hello all,
I'm having a hard time calculating the viscous dissipation term in my flow field. Basically what I'm doing is multiplying the shear stress tensor times the strain rate tensor. This is my expression: ViscousDiss_lead { type swakExpression; valueType cellZone; zoneName controlvolume35by25_lead; variables ( "viscousdiss_lead=0.002*(pow(grad(U).xx,2)) + 0.001*(pow((grad(U).xy+grad(U).yx),2)) + 0.002*(pow(grad(U).yy,2));" ); accumulations ( integrate ); expression "viscousdiss_lead"; verbose true; writeStartTime no; autoInterpolate true; warnAutoInterpolate false; autowrite true; } And the error I get: --> FOAM FATAL ERROR: Parser Error for driver CellZoneValueExpressionDriver at "1.1-4" :"field grad not existing or of wrong type" "grad(U)" ^^^^ --| I've seen other posts somewhat related to this but it seems it's not working when we try to use grad(U). I'm aware of snGrad but I can't use this one since what I want it's an integral of that in a specific cellZone. Any ideas on how to proceed? Thanks in advance! Bernardo |
October 15, 2019, 15:56 |
of4.1
Bernardo Ribeiro
Rep Power: 9 |
I managed to get a workaround if a replace grad(U) to gradU (rename it) but since this field is obtained in of4.1, I needed to change my patchField from extrapolatedCalculated to calculated and then it works...
Is it possible to use of4.1 with swak4foam? Thanks again in advance! |
Error while postProcessing icoFoam case to get grad(U) | shashanktiwari619 | OpenFOAM Post-Processing | 1 | July 29, 2019 02:47 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
Question on the sequence of grad(U) components | ripperjack | OpenFOAM Post-Processing | 1 | September 18, 2018 12:19 |
div(phi,U) linearUpwind default; or div(phi,U) linearUpwind grad(U); | cyln | OpenFOAM Running, Solving & CFD | 8 | August 1, 2018 08:46 |
[swak4Foam] different values between swakExpression & faceSource areaAverage | Paebin | OpenFOAM Community Contributions | 7 | December 23, 2015 11:29 |
