[swak4Foam] How to map fields using patches of type mappedPatch
Old   November 10, 2019, 15:13
Default How to map fields using patches of type mappedPatch
celestial is on a distinguished road
Good day swak4Foam members
I have an air solid interface. So, I call the temperature field, Ta, on the air side and Ts on the solid side.
For the sake of argument, let's say that for a certain boundary field patch inside dictionary 0/Ta,
I write
Ta = mappedInternal(Ts);
When I run my program, I get the error
field Ts is not existing or of wrong type
(but I created Ts in createFields.H. I ts is of the same type as Ta and my main code does not complain about it)
Now, if instead I write
Ta = mappedInternal(Ta);
the error goes away. Does that mean swakFoam knows that it has to look at Ts on the solid side simply because out of a multitude of different fields one can create on any given mesh, Ts will be the only one with the same dimensional units as Ta ?
That better be the answer, otherwise, I really don't know how
can make any sense.
Have a nice weekend,
Marc
celestial is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 05:49
Strange high velocity in centrifugal pump simulation huangxianbei OpenFOAM Running, Solving & CFD 26 August 15, 2014 02:27
SimpleFoam - instable simulation Specialist OpenFOAM Running, Solving & CFD 17 August 12, 2014 04:52
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 17:18
