Dimples in Mesh
4 Attachment(s)
I have been trying cfMesh for the past couple weeks and ran into some problems where I would get dimples in my mesh near surfaces. Another problem is that you can see the structure of the input surface mesh in the final volume mesh. You can see what I mean in the attached images. So far I have generated my input surface files by following this workflow. Up until this point my geometries have been very simple and just consist of a dice in a cuboid channel and a cylinder in a cuboid channel. I use FreeCAD to create the geometries and export them into a .step file before generating the surface mesh in salome. I tried to solve those problems by refining the mesh in the problematic regions (in cf;esh as well as in salome) and generating a new input surface file from the volume mesh using the foamToSurface utility. Although none of that brought any improvement. I think that there is something severely wrong with the way I generate my input surface file but I can't seem to figure out what exactly. Therefore I was hoping someone here might know what could cause those issues. If needed I can also provide the surface and meshdict files. best regards, Alissa Edit 1: -Provided download Links for the case directories. Including meshDict, checkMesh outputs and input files. -I also added the content of the meshDict files for those who don't want to download anything Edit 2: -Provided tech draws for each case dice Inside Channel https://drive.google.com/drive/folde...eBYWdWObAFYEPy meshDict for diceInsideChannel Code:
*--------------------------------*- C++ -*----------------------------------*\ zylinder Inside Channel https://drive.google.com/drive/folde...3vj3HEWqB4z-Ok meshDict for zylinderInsideChannel Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
Hi Alissa,
Without seeing the meshDict nad checkMesh results it is difficult to add anything. If it is not an important geometry, you can post the figure of original geometry along with the dimensions. |
Hi Krao,
thank you for your reply. Yes it’s not an important geometry so I am able to provide download links for the entire case directories. They’re just very simple cases I created to get more familiar with cfMesh after tinkering with the provided tutorial cases. I also added the content of the meshDict files to my original post for those who would rather not download anything. Unfortunately I didn’t have the time to create figures with the measurements of my geometries yet, but I can provide those later today. However the case directories include the original CAD files. Please let me know if there’s anything else I can do to provide useful insight to the problems I have. In the mean time I tried the surfaceGenerateBoundingBox utility (using a stl from FreeCAD as input) to create the fluid domain instead of following the workflow I linked in my original post. This seems to yield better results, but I still have to give it more testing. Regardless of that I’d like to figure out where I went wrong in my other attempts. best regards, Alissa p { margin-bottom: 0.25cm; line-height: 115%; background: transparent none repeat scroll 0% 0%; } |
Hi Krao,
it seems like my last reply isn't being displayed, so I'm sorry if this might show up as a double post later. Since these cases are just something simple, I created to get more familiar with cfMesh after tinkering with the provided tutorials, I was able to upload the entire case directories. In addition, I added the content of the controlDicts to my original post. I also provided the tech draws. I'm sorry that the figures are a bit crude (FreeCAD isn't my friend yet), but as you can see those are very simple geometries which shouldn't be a problem for the mesher. I also tested the surfaceGenerateBoundingBox utility, using a stl-file created with FreeCAD as input, which seems to yield better results. However, if possible, I'd still like figure out where my mistakes are with my current workflow. Feel free to ask me for anything else I could provide that gives a better insight to my current situation. best regards, Alissa |
OpenFOAM and related software use 'm' as dimension. The geometry you have posted is having a maximum width of 1000mm and that means only 1m. Your max cell size is 0.025m, with this size you are not refining enough(only 40 parts along the width and much less number of parts in other places). Also, please go through the CFmesh user guide, there are so many other options available. Start with some simple cube, later a cylinder, sphere etc., Once you are comfortable handling these geometries then you can explore more. http://cfmesh.com/wp-content/uploads...fMesh_v1.1.pdf |
I’m sorry for the late response. Of course I studied the cfMesh user Guide prior to my original post and tried various different options and settings. And I am aware that cfMesh uses meter as it’s base length unit. Unfortunately I didn’t keep a good record of my prior iterations so I can only try to recollect and describe the results from my memory. But I will make sure to keep a better record of each iteration from now on, so I can give more and better information when asking questions in the future. The major things I tried were: -Trying different mesh types. All ended up with the same problems. However cartesianMesh still got the best mesh. -local & object refinement (down to a cell size of about 1mm) with limited cell size and additional refinement levels. In all cases the dimples became smaller, but never completely vanished. -keepCellsIntersectingBoundary/Patches. This inverts the dimples, which is quite obvious since the dimples are clearly cells that intersect the boundary of the object and are removed by the mesher by default. -stopping the workflow at various steps, hoping to figure out at which point the mesher runs into problems. Although I don’t remember if this turned out to be useful or not. Perhaps I should revisit this step. -enforcingGeometryConstraints did nothing as far as I remember. I also tested various utilities. However most of those also don’t seem to help in solving my problems. I only managed to achieve a good result for the die/cube by fist generating a template with cfMesh, converting the volume mesh into a surface mesh via foamToSurface and then generate a new volume mesh from that after extracting the feature edges and converting it into an ftr/fms file. Another way to achieve a satisfactory result was to by using the surfaceGenerateBoundingBox utility. I would prefer to find a different way to achieve good enough results though, since those methods appear too cumbersome when working with more complex problems in the future, because I don’t seem to have much control about local refinement when going one of those routes. In addition I tested different refinement levels with the netgen2d-1d algorithm in salome over the past couple. This helped to reduce the size of the “dimples” but increased the quantity of dimples. I was only able to go down to a cell size of about 1 mm before my computer would crash though. Before trying mesh objects that are placed in a flow channel, I also meshed various geometries that had all kinds of round edges, bevels, indentation etc. to get a feeling for how to use cfMesh. All those cases worked like a charm without having to use additional options, except for some refinements here and there. It was only when I placed those objects in a channel that I started to run into problems. p { margin-bottom: 0.25cm; line-height: 115%; background: transparent none repeat scroll 0% 0%; } |
I’m digging up my old thread because I’m still a bit stuck. As mentioned in my previous post I’m able to achieve decent meshes using the generateBoundaryBox utility. For simple stuff I find it to be quite easy to generate meshes which can at least pass the checkMesh and properly capture all geometrical features. However I would much rather prefer being able to create a 3D-Model of my fluid domain in a CAD Software and mesh it using the workflow (or one similar to the one) I linked in my original post. So I’m still hoping that someone here can give me good hint as to what I should look out for when generating my Mesh. As of now I’m still convinced that there’s a major flaw in the process of generating my surface file. On order to test this I created the fluid domain for the same geometry (zylinderInsideChannel) using two different methods. First I created a 3D Model of my fluid domain in FreeCAD and then generated a surface mesh from the 3D-Modell using Salome. When running the checkSurfaceMesh utility it results in 4 failed checks and generating a good volume mesh seems to be next to impossible. Code:
Number of points 347145 In my understanding this should result in a mesh equal in quality to the one from above. However this mesh only fails 2 checks when running the checkSurfaceMesh utility and generating a volume mesh from it is no problem at all. Code:
Number of points 291827 Based on the check mech results, does anyone here have an idea where there might a problem with my workflow? The most notable difference in the mesh checks of the of the surface meshes is in my opinion that the first one consists of 11 manifolds and the second one only of 2 manifolds. |
Hi
Can you provide the full case or at least the STL files? Best would be all in a zip folder. My first thought was there must be something wrong with your STL files. |
