[swak4Foam] Error compiling on Ubuntu 18.04 for OF v1612+
Old   December 30, 2019, 17:01
Default Error compiling on Ubuntu 18.04 for OF v1612+
B. Assaad
bassaad17 is on a distinguished road
Hi All,
I'm trying to compile swak4foam dev-version-0.4.1_v2.x for Ubuntu 18.04.3 LTS codename bionic for Openfoam.com Version v1612+ on a cloud machine.
I first source the code using this alias in my .bashrc file
alias of1612+='module load openmpi; source /home/ubuntu/OpenFOAM/OpenFOAM-v1612+/etc/bashrc WM_LABEL_SIZE=64 WM_COMPILER_TYPE=system'
Then I follow the instructins in https://openfoamwiki.net/index.php/I...tion/swak4Foam
I tried this by setting WM_LABEL_SIZE=32 and it doesn't work either.
I'm getting this error and can't figure out the solution for this - please help!
Make/linux64GccDPInt64Opt/plugins/PatchValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/CellSetValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/CellZoneValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/FaceSetValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/FaceZoneValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/SampledSetValuePluginFunction.o Make/linux64GccDPInt64Opt/plugins/SampledSurfaceValuePluginFunction.o -L/home/ubuntu/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt64Opt/lib \
    -lfiniteVolume      -lsampling -llagrangian         -ldynamicMesh   -lsurfMesh      -lmeshTools  -o /home/ubuntu/OpenFOAM/ubuntu-v1612+/platforms/linux64GccDPInt64Opt/lib/libswak4FoamParsers.so
/usr/bin/ld: cannot find -lfiniteVolume
/usr/bin/ld: cannot find -lsampling
/usr/bin/ld: cannot find -llagrangian
/usr/bin/ld: cannot find -ldynamicMesh
/usr/bin/ld: cannot find -lsurfMesh
/usr/bin/ld: cannot find -lmeshTools
collect2: error: ld returned 1 exit status
make: *** [/home/ubuntu/OpenFOAM/ubuntu-v1612+/platforms/linux64GccDPInt64Opt/lib/libswak4FoamParsers.so] Error 1
/home/ubuntu/OpenFOAM/OpenFOAM-v1612+/wmake/makefiles/general:167: recipe for target '/home/ubuntu/OpenFOAM/ubuntu-v1612+/platforms/linux64GccDPInt64Opt/lib/libswak4FoamParsers.so' failed
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
bassaad17 is offline   Reply With Quote
[OpenFOAM.org] Install OpenFOAM-2.4.0 in Ubuntu 18.04? luckyraymond OpenFOAM Installation 10 April 26, 2023 13:26
[OpenFOAM.org] Installing OpenFOAM 2.3 on Ubuntu 18.04 Joe1best OpenFOAM Installation 15 August 5, 2021 22:21
[Other] Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04 gcengineer OpenFOAM Installation 9 June 22, 2020 18:45
[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 jlr OpenFOAM Installation 4 January 3, 2019 12:57
[OpenFOAM.org] problem with instaling openfoam-2.0.0 on ubuntu 18.04 alireza.sh OpenFOAM Installation 11 November 22, 2018 11:09
