funkySetFields fatal error - Unknown patchField - hotRoom
Dear all,
I am trying to reproduce Bernhard's latest tutorial on swak4Foam from OFW14 using v-1906. I have gone successfully through the first steps of the hotRoom case but when I try to implement the "column of fire" initial condition with Code:
funkySetFields -time 0 -keepPatches -valuePatches "floor" -field T -expression "600" -condition "(pos().x>4.5 && pos().x<5.5 && pos().z>4.5 && pos().z<5.5)" Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
Current OpenFOAM version is v1906. Petros |
Not sure, but main functionalities of swak4Foam were transferred into OF starting from v1912. Please have a go to see if it helps.
Allow me to comment more on that issue though, hoping that it might be of any help. Using the 'banana' trick and running just the buoyantPimpleFoam it is clear that OpenFOAM offers 116 possible patchField types, including lumpedMassWallTemperature. Code:
--> FOAM FATAL IO ERROR: Code:
--> FOAM FATAL IO ERROR: |
I have had exactly the same problem, Petros.
Have you found a solution to this? regards, Tim Quote:
Hi Tim,
Unfortunately I haven't found what caused this. Petros |
Same problem for alphaContactAngle
Dear Petros
I also have a similar problem during initializing files for the multiphaseInterFoam solver. Unfortunately does not "alphaContactAngle" did you figure out how to solve it? Code:
--> FOAM FATAL IO ERROR: Quote:
Hi all,
For further reference, I have a workaround for that issue. If funkySetFields complains about a specific patch type, you can first set a dummy patch type for your boundary condition, say: Code:
yourPatchName01 After that, you can change the patch type to the type you want, using a changeDictionaryDict. For example: Code:
T |
