Andrea23 |
February 17, 2020 09:31 |
swak4foam openfoam 7 installation problem
i'm using ubuntu 18.04 on a windows shell and i have installed openfoam 7.
I have followed installation guide on this page:
https://openfoamwiki.net/index.php/I...ling_On/Ubuntu
and downloaded swak4foam developer version as indicated in 5.2.1. in this page:
https://openfoamwiki.net/index.php/I...opment_version
using these comand lines
after I used the comand: ./Allwmake > log.make 2>&1 ; I received no output and after using: funkySetFields this was the output:
swakVersion: 0.4.3 (Release date: Next release)
--> FOAM FATAL ERROR:
funkySetFields: time/latestTime option is required
From function main()
in file funkySetFields.C at line 713.
FOAM exiting
this is the log.make file:
Current OpenFOAM version is 7.
Previously compiled for OpenFOAM (7)
/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
No file 'swakConfiguration'. Python etc won't work. See README for details
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
Checking swak4Foam-version and generating file
Swak version is 0.4.3
hg info: f4fb37df715d (develop) tip
Bison: /home/andrea/OpenFOAM/andrea-7/run/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/andrea/OpenFOAM/andrea-7/run/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
Flex is version 2.6.4 (Minor version: 4)
OpenFOAM-version: Major 7 Minor 0 Patch -1 (-1 == x / 98) Fork: org
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
wmake libso swak4FoamParsers
wmake libso swakLagrangianParser
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/properties/solidMixtureProperties/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/properties/liquidMixtureProperties/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/properties/solidProperties/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/properties/liquidProperties/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/pdfs/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/liquids/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/liquidMixture/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/solids/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/solidMixture/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/thermophysicalModels/radiation/ does not exist
wmake libso groovyBC
wmakeLnInclude error: base directory /opt/openfoam7/src/immersedBoundary/immersedBoundary/ does not exist
wmake libso swakFunctionObjects
wmakeLnInclude error: base directory ADDITIONALFILES_INC=/opt/openfoam7/src/OpenFOAM/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/postProcessing/functionObjects/utilities/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/dynamicMesh/dynamicFvMesh/ does not exist
wmake libso simpleFunctionObjects
wmakeLnInclude error: base directory ADDITIONALFILES_INC:=/opt/openfoam7/src/OpenFOAM/ does not exist
wmake libso simpleLagrangianFunctionObjects
wmake libso simpleSearchableSurfaces
wmake libso simpleSwakFunctionObjects
wmakeLnInclude error: base directory /home/andrea/OpenFOAM/root-7/Libraries/simpleFunctionObjects/ does not exist
wmake libso swakTopoSources
wmake libso swakDynamicMesh
wmakeLnInclude error: base directory /opt/openfoam7/src/dynamicMesh/meshMotion/solidBodyMotion/ does not exist
wmake libso swakSourceFields
Compiling swakFvOptions
wmake libso swakFvOptions
wmake libso swakStateMachine
wmakeLnInclude error: base directory /opt/openfoam7/src/finiteArea/ does not exist
wmake libso groovyStandardBCs
No file 'swakConfiguration' in the top directory of the swak-sources. Language integrations probably won't work
wmake libso swakGeneralLanguageIntegration
SWAK_PYTHON2_INCLUDE not defined .... no Python2-Integration. Most people are fine without it
SWAK_PYTHON3_INCLUDE not defined .... no Python3-Integration. Most people are fine without it
SWAK_LUA_LINK not defined .... no Lua-Integration. Most people are fine without it
wmake libso swakScriptableLagrangian
wmake libso swakChemistryModelFunctionPlugin
wmake libso swakDynamicMeshFunctionPlugin
wmake libso swakFvcSchemesFunctionPlugin
wmake libso swakLagrangianCloudSourcesFunctionPlugin
wmake libso swakLocalCalculationsFunctionPlugin
wmake libso swakMRFFunctionPlugin
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/LES/LESdeltas/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/compressible/turbulenceModel/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/compressible/LES/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/compressible/RAS/ does not exist
wmake libso swakMeshQualityFunctionPlugin
wmake libso swakMeshWaveFunctionPlugin
wmake libso swakQuantileFunctionPlugin
wmake libso swakRadiationModelFunctionPlugin
wmake libso swakRandomFunctionPlugin
wmake libso swakShiftFieldFunctionPlugin
wmake libso swakSurfacesAndSetsFunctionPlugin
wmake libso swakThermoTurbFunctionPlugin
wmake libso swakTransportTurbFunctionPlugin
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/incompressible/turbulenceModel/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/incompressible/LES/ does not exist
wmakeLnInclude error: base directory /opt/openfoam7/src/turbulenceModels/incompressible/RAS/ does not exist
wmake libso swakVelocityFunctionPlugin
wmake libso coalCloudAdaptor
If you have your own function-plugins you can specify them using the SWAK_USER_PLUGINS environment variable and they would be compiled now. If you don't know what this means: don't bother. You propably don't need it
wmake libso simpleCloudFunctionObjects
wmake libso swakCloudFunctionObjects
wmake calcNonUniformOffsetsForMapped
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/calcNonUniformOffsetsForMapped'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/calcNonUniformOffsetsForMapped'
wmake fieldReport
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/fieldReport'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/fieldReport'
wmake funkyDoCalc
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkyDoCalc'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkyDoCalc'
wmake funkyPythonPostproc
SWAK_PYTHON2_INCLUDE not defined .... no Python-Integration. Utility funkyPythonPostproc not compiled
wmake funkySetAreaFields
wmake funkySetBoundaryField
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetBoundaryField'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetBoundaryField'
wmake funkySetFields
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetFields'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetFields'
wmake funkySetLagrangianField
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetLagrangianField'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkySetLagrangianField'
wmake funkyWarpMesh
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkyWarpMesh'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/funkyWarpMesh'
wmake replayTransientBC
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/replayTransientBC'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/replayTransientBC'
wmake writeBoundarySubfields
make[1]: Entering directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/writeBoundarySubfields'
make[1]: Leaving directory '/home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Utilities/writeBoundarySubfields'
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/andrea/OpenFOAM/andrea-7/run/swak4Foam/Libraries (most people will be fine without setting that variable)
Are these critical problems? How can I resolve them?
I am not very good with ubuntu and programming and let me know if you need more informations
