[cfMesh] generateBoundaryLayers failed - how to split edges |
June 25, 2021, 08:16 |
Rep Power: 5 |
I would like to create boundary layers (only!) on a certain patch of a complex geometry but their generation during the meshing procedure (cartesianMesh, OF v2006) doesn't work. The syntax I used is
boundaryLayers { nLayers 0; untangleLayers 0; patchBoundaryLayers { "boundarylayer.*" //patch name { allowDiscontinuity 1; nLayers 5; thicknessRatio 1.2; } } } Code:
Detecting layers Analysing mesh for bnd layer existence Generating hair edges Finished with bnd layer detection Finished refining boundary - layer faces Number of newly generated cells 107912 Finished generating new cells Code:
Splits in direction (1 5) Here Dir0 -1 dir0Edges (-1 -1) Dir1 -1 dir1Edges (-1 -1) --> FOAM FATAL ERROR: Cannot find split edges for a face |
boundary layers, cfmesh, generateboundarylayers, split edges |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Flow simulation in wind tunnel | mukut | OpenFOAM | 15 | September 11, 2013 22:43 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] multi-Region failed to split one of the regions | phsieh2005 | OpenFOAM Meshing & Mesh Conversion | 1 | April 26, 2010 07:26 |
