[cfMesh] CFMesh with OpenFOAM 7, binary format
Old   March 26, 2020, 08:05
Default CFMesh with OpenFOAM 7, binary format
benoit paillard
bennn is on a distinguished road
Hi all,
When trying to mesh a case in binary format in openfoam 7, the meshing works but checkMesh and solvers crash with
"Expected a ')' while reading binaryBlock"
Which reminds me of WM_LABEL_SIZE issues
If you mesh for instance sawOctree in the tutorials, checkMesh will crash.
I tried looking at the issue but no luck so far. Any idea ?
Thanks.
bennn is offline   Reply With Quote
Old   April 5, 2020, 20:27
Gabriel dos Santos
Niteck is on a distinguished road
I'm having the same issue here.
Fortunately, there are some possible workarounds.
1) Use another OpenFOAM version (e.g., OpenFOAM 5 or OpenFOAM v1912) to "convert" the constant/polyMesh data via the foamFormatConvert utility. I know, it is kinda redundant; but it works.
2) If one doesn't have another OpenFOAM distribution available, an alternative is to save the polyMesh data in ASCII and then convert it to binary. For that, I would suggest to set a higher writePrecision value in system/controlDict. Perhaps, something around 16 is good enough. Then, just generate the mesh using cfMesh, set writeFormat back to binary in system/controlDict, and run foamFormatConvert.
Hope this helps.
Niteck is offline   Reply With Quote
[cfMesh] Compiling cfMesh with OpenFOAM 4.x dkokron OpenFOAM Community Contributions 16 August 15, 2018 11:26
Parse OpenFoam polyMesh in binary stream format Daniel1966 OpenFOAM Programming & Development 1 March 22, 2018 05:12
[Commercial meshers] ICEM mesh file in correct format for OpenFOAM SamEngD OpenFOAM Meshing & Mesh Conversion 0 April 5, 2017 06:29
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
