Compling in OpenFOAM-v1912 faceSetToSTL fatal error
Hi Sir,
I was trying to compile waves2Foam in OpenFOAM-v1912. While compiling, I encountered the following error. At first I noticed in the OceanWave3D compiling section, src/initialization/Initialize.f90:48:18: WRITE(fileop(1),*),'Error: Problem with specified input file.' 1 Warning: Legacy Extension: Comma before i/o item list at (1) And in this section, ===================================== COMPILE PRE-PROCESSING ===================================== wmake faceSetToSTL ... Making dependency list for source file faceSetToSTL.C wmkdepend: could not open 'foamTime.H' for source file 'faceSetToSTL.C': No such file or directory wmkdepend: could not open 'faceTriangulation.H' for source file 'faceSetToSTL.C': No such file or directory wmkdepend: could not open 'triSurface.H' for source file 'faceSetToSTL.C': No such file or directory faceSetToSTL.C:56:10: fatal error: faceTriangulation.H: No such file or directory #include "faceTriangulation.H" ^~~~~~~~~~~~~~~~~~~~~ compilation terminated. /home/simucentral/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/faceSetToSTL.o' failed And in the end, it showed this, ===================================== COMPILE BREEDER ===================================== Nothing available for compilation in the breeder directory. ===================================== COMPILATION DONE ===================================== Is this normal? Do I have a successful completion of waves2Foam now? Sorry, I am an absolute beginner. Can you please enlighten me on this? Can I make simulations on irregular waves using this version? Thank you so much. |
I tried to do the step again. This is the full log.
v1912 ===================================== ENVIRONMENTAL VARIABLES ===================================== EXTBRANCH=0 FOAMEXTENDPROJECT=0 OFPLUSBRANCH=1 WAVES_APPBIN=/home/simucentral/OpenFOAM/simucentral-v1912/platforms/linux64GccDPInt32Opt/bin WAVES_DIR=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam WAVES_GSL_INCLUDE=/usr/include WAVES_GSL_LIB=/usr/lib64 WAVES_LIBBIN=/home/simucentral/OpenFOAM/simucentral-v1912/platforms/linux64GccDPInt32Opt/lib WAVES_POST=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/postProcessing WAVES_PRE=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing WAVES_SOL=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/solvers/solvers1912_PLUS WAVES_SRC=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/src WAVES_TUT=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/tutorials WAVES_UTIL=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities WAVES_XVERSION=0 WM_PROJECT_VERSION_NUMBER=1912 ===================================== COMPILE LAPACK-3.3.1 ===================================== lapack-3.3.1 has already been compiled ===================================== COMPILE SPARSKIT2 ===================================== SPARSKIT2 has already been compiled ===================================== COMPILE OCEANWAVE3D ===================================== Pull changes from the OceanWave3D git repository ... Saved working directory and index state WIP on master: bb7d99e bug fix for calling OceanWave3D Already up to date. On branch master Your branch is up to date with 'origin/master'. Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git checkout -- <file>..." to discard changes in working directory) modified: common.mk modified: makefile no changes added to commit (use "git add" and/or "git commit -a") Dropped refs/stash@{0} (7938bab451ff38c15143839641b4d8b763466cb0) OceanWave3D has already been compiled /home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/ThirdParty ===================================== COMPILE FENTON4FOAM ===================================== fenton4Foam has already been compiled ===================================== COMPILE LIBRARY ===================================== v1912 wmake libso (waves2Foam) wmake libso (waves2FoamProcessing) wmake libso (waves2FoamSamplingNew) wmake libso (waves2FoamPorosity) ===================================== COMPILE SOLVERS ===================================== ===================================== COMPILE PRE-PROCESSING ===================================== wmake faceSetToSTL make[1]: Entering directory '/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/triSurface/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -DOFVERSION=1912 -DEXTBRANCH=0 -IlnInclude -I. -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude -fPIC -c faceSetToSTL.C -o Make/linux64GccDPInt32Opt/faceSetToSTL.o faceSetToSTL.C:56:10: fatal error: faceTriangulation.H: No such file or directory #include "faceTriangulation.H" ^~~~~~~~~~~~~~~~~~~~~ compilation terminated. /home/simucentral/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/faceSetToSTL.o' failed make[1]: *** [Make/linux64GccDPInt32Opt/faceSetToSTL.o] Error 1 make[1]: Leaving directory '/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL' /home/simucentral/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/apps:29: recipe for target 'faceSetToSTL' failed make: *** [faceSetToSTL] Error 2 ===================================== COMPILE POST-PROCESSING ===================================== ===================================== COMPILE BREEDER ===================================== Nothing available for compilation in the breeder directory. ===================================== COMPILATION DONE ===================================== Posting this update in the hope that it will provide more info. |
With this setup, I tried to run the 3DWave tutorial problem. However, I couldn't run the case. In the log.faceSet and the subsequent log files, it says..
/home/simucentral/OpenFOAM/OpenFOAM-v1912/bin/tools/RunFunctions: line 228: faceSet: command not found Any advice on how to proceed? |
Hallo,
I just tried compiling under 1912 with a clean check-out from the repository. It compiled without any problems. The missing faceSet is due to a obsolete functionality in OpenFoam. Please adjust by using topoSet instead. Kind regards Niels |
1 Attachment(s)
Hi Niels,
Thank you so much for your quick response. :) As advised, I did a clean up and did a fresh check out and compiled again. I ran the 3Dwaves tutorial problem again. The faceSet showed the same error. However, the waveFoam completed the run. This is the first look. https://1.bp.blogspot.com/-Lcow1VGap...3Dwaves_01.png I will try with topoSet instead of faceSet, then I will need the topoSetDict.I will have to study more to get that right. I was going to compile v1812 actually. Thank you Niels. Warm Regards, Akram |
