July 8, 2020, 13:48 |
swak4Foam on OpenFoam-v2006?
Petros Ampatzidis
Rep Power: 7 |
Is there any chance to compile swak4Foam for the new OpenFOAM-v2006 release? I gave it a try but with no success: Code:
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam cd swak4Foam ./AllwmakeAll > log.make 2>&1 Code:
Current OpenFOAM version is v2006. Previously compiled for OpenFOAM (v2006) /home/petros/OpenFOAM/petros-v2006/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' Looking for Python 2 Found Python 2.7 Configuring Python 2.7 Using python2.7 at /usr/bin/python2.7-config for python2 Looking for Python 3 Using our own Lua at /home/petros/OpenFOAM/petros-v2006/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 2020.06.0 hg info: 76087ce82a32 tip No 'bear' installed Bison: /home/petros/OpenFOAM/petros-v2006/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/petros/OpenFOAM/petros-v2006/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 2006 Minor 0 Patch 0 (-1 == x / 0) Fork: com No change to swak4FoamParsers/foamVersion4swak.H Petros |
July 20, 2020, 14:27 |
Still trying to compile swak4Foam in v2006
Petros Ampatzidis
Rep Power: 7 |
Still trying to compile swak4Foam in v2006 after Bernhard announced that it is now fully functional.
I get the following fatal error: Code:
In file included from facInterpolationFunctionPlugin.C:33:0: ../../swakFiniteArea/lnInclude/FaFieldValueExpressionDriver.H:49:47: fatal error: FaFieldValueExpressionParser.tab.hh: No such file or directory #include "FaFieldValueExpressionParser.tab.hh" |
November 12, 2020, 10:54 |
Eoin
Hi Petros,
Did you ever manage to find the cause of this error? Getting the same message here trying to install swak4Foam on OpenFoam-v2006. Thanks |
November 12, 2020, 11:33 |
Petros Ampatzidis
Rep Power: 7 |
I can confirm that swak4Foam compiles smoothly with v2006 after Bernhard Gschaider's newer updates. Try: Code:
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam cd swak4Foam ./AllwmakeAll |
November 13, 2020, 13:57 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I'm not 100% sure if the latest release (that would be the one pulled by your command) compiles completely with your command as it was released before v2006 (I did some adaptions according to the git that would become 2006 which compile most of it) To be sure do Code:
hg update develop
January 15, 2021, 06:10 |
Giovanni Giustini
Hi Bernhard,
I am trying to compile as well, but so far unsuccessfully: Reading variables from 'swakConfiguration' Looking for Python 2 Found Python 2.7 Configuring Python 2.7 Using python2.7 at /usr/bin/python2.7-config for python2 Looking for Python 3 Using our own Lua at /opt/OpenFOAM-v2006/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 20xx.yy.0 hg info: b8e73355892c (develop) tip No 'bear' installed Bison: /opt/OpenFOAM-v2006/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /opt/OpenFOAM-v2006/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 2006 Minor 0 Patch 0 (-1 == x / 0) Fork: com No swak4FoamParsers/foamVersion4swak.H. Generated Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem ln: simpleFunctionObjects/lnInclude wmake libso swak4FoamParsers /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:71: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:72: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:71: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:72: /opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. wmake error: file '/opt/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /opt/OpenFOAM-v2006/swak4Foam/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it Any suggestion about what may have caused the issue? Best wishes, Giovanni |
April 7, 2021, 23:28 |
Rep Power: 5 |
Hi Bernhard,
I am trying to compile swak4foam on OFv2012 and have done the hg update, but meet an error: Reading variables from 'swakConfiguration' Looking for Python 2 Found Python 2.7 Configuring Python 2.7 Using python2.7 at /usr/bin/python2.7-config for python2 Looking for Python 3 Found Python 3.6 Configuring Python 3.6 Using python3.6 at /usr/bin/python3.6-config for python3 Using our own Lua at /home/user2/OF2012/OpenFOAM/user2-v2012/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 20xx.yy.0 hg info: b8e73355892c+ (develop) tip which: no bear in (/home/user2/OF2012/OpenFOAM/user2-v2012/swak4Foam/privateRequirements/bin:/OF2012/OpenFOAM/user2-v2012/platforms/linux64GccDPInt32Opt/bin:/home/user2/OF2012/OpenFOAM/OpenFOAM-v2012/site/2012/platforms/linux64GccDPInt32Opt/bin:/home/user2/OF2012/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin:/home/user2/OF2012/OpenFOAM/OpenFOAM-v2012/bin:/home/user2/OF2012/OpenFOAM/OpenFOAM-v2012/wmake:/home/user2/dakota-6.9.0-release-public-rhel7.x86_64-UI/bin:/home/user2/dakota-6.9.0-release-public-rhel7.x86_64-UI/share/dakota/test:/home/user2/dakota-6.9.0-release-public-rhel7.x86_64-UI/gui:/usr/local/MATLAB/R2015b/bin:/usr/ansys_inc/v171/fluent/bin:/usr/ansys_inc/v171/icemcfd/linux64_amd/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/user2/.local/bin:/home/user2/bin) No 'bear' installed Bison: /home/user2/OF2012/OpenFOAM/user2-v2012/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/user2/OF2012/OpenFOAM/user2-v2012/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.5.37 (Minor version: 37) OpenFOAM-version: Major 2012 Minor 0 Patch 0 (-1 == x / 0) Fork: com No change to swak4FoamParsers/foamVersion4swak.H Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem wmake libso swak4FoamParsers mkdir: cannot create directory '/OF2012/OpenFOAM/user2-v2012/platforms': Permission denied make: *** [/OF2012/OpenFOAM/user2-v2012/platforms/linux64GccDPInt32Opt/lib/libswak4FoamParsers.so] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it. I have tried: 1.Manually create the directory '/OF2012/OpenFOAM/user2-v2012/platforms'. 2.Apply "chmod -R 777 user2-v2012/". Both can't solve the problem and the error message is the same. Could you please give me a hint? Thank you in advance. Ron |
April 8, 2021, 08:07 |
Problem solved!
#8 | |
Rep Power: 5 |
The solution for my case is to change the WM_PROJECT_USER_DIR in bashrc to right user directory.Then $FOAM_USER_LIBBIN will be corrected automatically. I hope it will help someone. Ron |
July 26, 2021, 10:00 |
swak4Foam download issue
sw choi
Rep Power: 5 |
Dear Mr. Ron.CC
Thanks for your sharing your experience. I am new OF user and try to download the swak4foam on OFv2012 but I have a error message as follows. I used below command in my Ubuntu terminal: hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam Please see the attached snapshot of error message. I have no clear idea what cased the problem. It would be great if you can give me any comments on this issue. |
July 26, 2021, 12:32 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Try downloading from a shell where OpenFOAM is not activated For reasons like this I recommend NOT activating OpenFOAM in your bashrc automatically because it is possible with such a library mixup to lock yourself out completely Last: PLEASE don't post screenshots of your error messages. Copy the text from the terminal and put it into a CODE-environment (the #-icon above). This makes it easier to answer your questions because people can copy-past from it and it helps other people with similar problems because the problem is found when searching for the error message
July 30, 2021, 15:41 |
#11 |
sw choi
Rep Power: 5 |
Dear Mr. gschaider
I do appreciate your kind and detail suggestions. I am in the middle of understanding your comments. I am new to use Unix environment. Even though I have a experience of simply modifying the source code, but I still feel uncomfortable to work in Unix environment. In addition, I am using the Ubuntu to run OpenFOAM. I have no idea how to get the error message on the Ubuntu terminal. That's way I made a snap shot. Anyhow, I learn a lot thanks to your valuable help and suggestions.. Thank you again. Sung |
August 1, 2021, 06:46 |
#12 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
First: to get the error message from the terminal just copy-paste it like you would with any regular text What happens is that when OF is "activated" it manipulates an environment variable LD_LIBRARY_PATH that tells Linux where to look for so-files (the equivalent to DLLs in Windows and Windows has a similar mechanism with the PATH-variable). Now your OpenFOAM-version (you never mention where you get these binaries from) bring their own version of libstdFoo.so in /opt/foo (instead of foo I could give you the correct names if I could copy paste them from your post but I can't copy them from your screenshot). There is a so-file of the same name in your system (probably in /usr/lib or /lib). But as the /opt/foo-directory comes in the LD_LIBRARY_PATH before that your system uses that one. Now the problem seems to be that the version on your system is Newer than the version in /opt/foo and a lot of programs (like your python in that case) rely on the newer version and fail because they stop searching after they found the old version A lot of OF-installation-recipies recommend adding something like "source /opt/foo/.../etc/bashrc" to the ~/.bashrc so that you automatically have OF on your terminals. This is bad practice because it leads to problems like yours and in extreme cases can prevent you from logging in. I strongly recommend removing such a line from your ~/.bashrc (or similar file) and activate OF only when you need it
August 2, 2021, 10:25 |
#13 |
sw choi
Rep Power: 5 |
Dear Mr. gschaider
I don't know how to appreciate your kind and very helpful tips. You are the first expert to reply my question on not only prompt but also giving me a detail information. Your kindness and valuable comments are very very useful and guideline for the new OF users like me. Typically, the prompt reply is very very helpful for me to get to the correction direction. I have also many experience in OF to spend somewhat time to get the answer with wrong direction in this OF forum site due to delay of reply or no reply. To some point, I also learned it from my effort with non-successful result but the my working fund resources and boss does not allows me to do that (academical approach). Anyhow, your comments will be big guide line for the other reviewers on this issue. |
August 7, 2021, 09:18 |
#14 |
Eren
Rep Power: 8 |
I needed additional computational source, so I downloaded OF2012 with ubuntu on windows. Couldn't compile swak4foam for hours, then I switched to OF2006 and now it compiles nicely. So, if you have problem with OF2012, switch back to OF2006.
August 8, 2021, 14:41 |
#15 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Could you be a bit more specific about your problems? The latest release of swak4foam compiles with 2012 for me. If I don't hear about problems that some people might have in specific configurations it is very unlikely that these problems will get fixed
August 10, 2021, 05:35 |
#16 | |
Eren
Rep Power: 8 |
I can't reproduce error right now, when run finishes (it will probably take three-four more days) I'll do it and share it. But what I remember was bison didn't compile, I downloaded it myself. There was no error with dependencies (I downloaded everything myself starting from "essentials") but I got errors like: "/a/path/I/cant/recall/mybison not found" "cannot create directory" etc. |
August 10, 2021, 05:50 |
#17 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
"Can not create directory" usually is an OS-problem. Usually - a full disk - user has no permissions to create that directory
August 10, 2021, 07:23 |
#18 | |
Eren
Rep Power: 8 |
Well problem was neither of those. Because it compiled with 2006 without that problems. I will share the exact errors when I can touch the PC again(cpu is overwhelming right now). |
October 14, 2021, 05:47 |
#19 |
Eren
Rep Power: 8 |
Sorry about extremely late reply, this was on a remote computer(not mine) and I was extremely busy with writing new paper, job interviews and PhD proposal... Anyway, after using
hg update develop ./AllwmakeAll Reading variables from 'swakConfiguration' Looking for Python 2 Found Python 2.7 Configuring Python 2.7 Using python2.7 at /usr/bin/python2.7-config for python2 Looking for Python 3 Checking swak4Foam-version and generating file Swak version is 202x.yy.0 hg info: 06fdbe848844 (develop) tip Using /usr/bin/bear to build compilation database Bison: /home/erenc/OpenFOAM/OpenFOAM-v2012/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/erenc/OpenFOAM/OpenFOAM-v2012/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 2012 Minor 0 Patch 0 (-1 == x / 0) Fork: com No swak4FoamParsers/foamVersion4swak.H. Generated Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem ln: simpleFunctionObjects/lnInclude wmake libso swak4FoamParsers /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:71: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:72: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:61: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:71: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:72: /home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. wmake error: file '/home/erenc/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /home/erenc/OpenFOAM/OpenFOAM-v2012/swak4Foam/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it @gschaider |
October 14, 2021, 15:05 |
#20 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
OK. The problem is that the build-scripts assume that the OBJECT_DIR-variable set up by the wmake-script points to a directory inside the Make-directories in the sources. Then the relative references like "../myflex" work (because they are in the Make-directories). In your case it points to a directory in the /home/erenc/OpenFOAM/OpenFOAM-v2012/build-directory and therefore the relative path doesn't work anymore. I forgot when wmake makes the decision to compile to outside the sources. Either because some environment variables are missing. Or because things are compiled as root. You don't compile as root (with sudo) by any chance?
openfoam-v2006, swak4foam |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[swak4Foam] Error: Installing swak4Foam into OpenFOAM 2.3.0 on CentOS 7 | mushtime | OpenFOAM Community Contributions | 9 | July 23, 2017 15:27 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
