July 17, 2020, 14:32 |
plm_rsh_agent path not found
Rep Power: 10 |
The following command has no problem
mpirun porousSimpleFoam -parallel However, when I use pyFoam, I get an error about plm_rsh_agent path not found: Code:
$ pyFoamPlotRunner.py --procnr=16 porousSimpleFoam PyFoam WARNING on line 144 of file /home/marzieh/.local/lib/python3.6/site-packages/PyFoam/Execution/ParallelExecution.py : which can not find a match for porousSimpleFoam . Hoping for the best -------------------------------------------------------------------------- The value of the MCA parameter "plm_rsh_agent" was set to a path that could not be found: plm_rsh_agent: rsh Please either unset the parameter, or check that the path is correct -------------------------------------------------------------------------- Killing PID 28219 Any idea about that? |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
wmake error | zxj160 | OpenFOAM | 0 | March 26, 2012 10:52 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
