[IHFOAM] compilation error on openfoam-v2006
Old   November 12, 2020, 06:41
Default compilation error on openfoam-v2006
Aswani K Madhu
Aswani K Madhu is on a distinguished road
Hi IHFOAM Team,
First of thanking you for making IHFOAM AND olaFlow tutorials available openly.
I am using OpenFOAM from last month only. I could run the tutorial cases of interfoam. It is really exciting to know about IHFOAM and olaFlow but I am getting error while installing ihfoam and olaflow. This happens when ./allMake script is running on my terminal.
OpenFoam version installed is OpenFOAM-v2006
Ubuntu 20.04 LTS is used.
This is how it comes...
:~$ cd IHFOAM/
:~/IHFOAM$ ls
README.md genAbs reference.zip solvers tutorials
:~/IHFOAM$ cd genAbs/
:~/IHFOAM/genAbs$ ls
allMake common waveAbsorption waveGeneration
:~/IHFOAM/genAbs$ ./allMake
wmake libso waveGeneration
/opt/OpenFOAM/OpenFOAM-v2006/wmake/wmake: line 624: make: command not found
/opt/OpenFOAM/OpenFOAM-v2006/wmake/wmake: line 627: make: command not found
wmake error: file 'Make/linux64Gcc63DPInt32Opt/sourceFiles' could not be created in /home/aswani/IHFOAM/genAbs/waveGeneration
\n\nWave generation boundary conditions compilation failed
Please help me to correct this error and make use of this excellent solvers.
Also I like to know which version of IHFOAM is compactible for OFv2006.
I like to do the breakwater tutorial case.
Kind regards,
Aswani
Aswani K Madhu is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[OpenFOAM.org] OpenFOAM 5.0: sudden new compilation error on on the Titan supercomputer (Cray) wildfire230 OpenFOAM Installation 1 July 15, 2018 10:06
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 19:20
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit keepfit OpenFOAM Installation 2 March 26, 2013 09:43
