[swak4Foam] ./AllwmakeAll wmake not found error
Old   March 24, 2021, 15:15
Default ./AllwmakeAll wmake not found error
Gennaro Della Volpe
jennysins is on a distinguished road
Hi everyone, i would like to ask you for heo regarding an error encountered in the installation of swak4foam on Ubuntu 20.10 version.
I followed the instrucions of the following link https://openfoamwiki.net/index.php/Contrib/swak4Foam, and i get:
gennaro@gennaro-VirtualBox:~/openFOAM/swak4Foam$ ./AllwmakeAll
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/gennaro/openFOAM/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
Current OpenFOAM version is .
Previously compiled for OpenFOAM ()
/home/gennaro/openFOAM/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Looking for Python 3
Using our own Lua at /home/gennaro/openFOAM/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 2020.06.0
hg info: 76087ce82a32+
Using /usr/bin/bear to build compilation database
./Allwmake: riga 78: wmake: comando non trovato
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
How can i resolve?
ty all
jennysins is offline   Reply With Quote
Old   March 24, 2021, 19:59
Assistant Moderator
Bernhard Gschaider
How can i resolve?
ty all
You have not "activated" any OpenFOAM distro on the shell you're on (meaning: wmake is not in your path, the environment variables are not set up etc). Before compiling do whatever you usually do on a shell before you run OpenFOAM solvers and utilities
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 25, 2021, 02:06
Gennaro Della Volpe
what do you mean "not activated"? sorry, but i'm very newby to thiss stuff
UPDATE: i think i've activated the OF 2012 version, and run ./AllwmakeAll and get this:
./AllwmakeAll
Current OpenFOAM version is v2012.
This is a clean install
any suggestion?
Old   March 25, 2021, 15:28
Assistant Moderator
Bernhard Gschaider
./AllwmakeAll
any suggestion?
"Activated" means sourcing the bashrc that sets up the environment. But you seem to have figured that out because in your new error message the OF-version is installed. I assume that the "commando no trovato" means "command not found". wmake is part of OF and essential for compiling ANYTHING on OpenFOAM. I assume that you installed some binary-package where it was left off to save space (the sources probably too). Have a look whether there is an additional package with devel/develop in the name and install that (I have no other explanation for a missing wmake)
Old   March 26, 2021, 04:14
Gennaro Della Volpe
i've tryed to input these commands:
sudo apt-get install openfoam2012
sudo apt-get install openfoam2012-dev
sudo apt-get install openfoam2012-tutorials
sudo apt-get install openfoam2012-default
sudo apt-get install openfoam2012-tools
to be sure that i've installed all packages, but i got the same command line error that i report above.
p.s. in the usr/lib/openfoam/openfoam2012, there is wmake directory, so why is still not work the ./AllwmakeAll command?
Old   March 29, 2021, 14:59
Assistant Moderator
Bernhard Gschaider
And the actual wmake utility is in the directory. Usually it is in the PATH-variable and therefore found. I guess it is a problem with the apt-packages (can't tell. I don't use them)
Try export
export PATH=wmakedir:$PATH
(with wmakedir being the path to the wmake-directory). That should fix things for the current shell
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
