[cfMesh] CfMesh v1.1.2 not working as expected with OpenFOAM 8 |
January 21, 2021, 00:34 |
Akash Patel
Rep Power: 7 |
I have tried meshing same geometry (bunny mesh in cfmesh examples) with OpenFOAM 5/6/7, and OpenFOAM 8. It works flawlessly when compiled with OpenFOAM 5/6/7 but fails to complete the process (stuck at "found x inverted boundaries") when compiled with OpenFOAM 8.
Meshers I have encountered same problem with are Cartesian2DMesh, CartesianMesh, tetMesh, and pMesh. Has anyone tried using CfMesh with OpenFOAM 8?
We are developing an open-source software for constructing reduced order models for your CFD simulations in OpenFOAM that runs several magnitude faster. Visit the link below to learn more. AccelerateCFD - OpenFOAM based reduced order model solver for CFD using Proper Orthogonal Decomposition. |
February 14, 2021, 10:19 |
Rep Power: 8 |
Hey,
can you please tell, how you edit the /meshLibary/Make/Options file. I cant even install cfMesh on OF8. I got an Error if i execte ./Allwmake > log.make 2>&1 Best regards Kai |
February 14, 2021, 13:49 |
Akash Patel
Rep Power: 7 |
Can you post your error log here? I can help you with that.
February 15, 2021, 11:20 |
Rep Power: 8 |
Thank you very much.
I downloaded the cfMesh-v1.1.2.tgz folder unzip it, and copied it to my OF8 folder in "~/OpenFOAM/kai-8". I edited the "cfMesh/meshLibary/Make/Options" file like this: Code:
ifeq (Gcc,$(findstring Gcc,$(WM_COMPILER))) OMP_FLAGS = -DUSE_OMP -fopenmp else OMP_FLAGS = endif ifeq (OpenFOAM,$(findstring OpenFOAM,$(WM_PROJECT))) ifeq (Int,$(findstring Int,$(WM_LABEL_OPTION))) CFMESH_MACROS = -DNoSizeType LIBS = else CFMESH_MACROS = LIBS = endif endif ifeq (v, $(findstring v, $(WM_PROJECT_VERSION))) CFMESH_MACROS += -DOpenCFDSpecific endif ifeq ($(WM_PROJECT), foam) VER := $(shell expr `echo $(WM_PROJECT_VERSION)` \>= 3.2) ifeq ($(VER), 1) CFMESH_MACROS = -DExtendSpecific -std=c++11 LIBS = -lmeshTools -ledgeMesh else CFMESH_MACROS = endif endif EXE_INC = \ $(OMP_FLAGS) $(CFMESH_MACROS) \ -I$(LIB_SRC)/triSurface/lnInclude \ -I$(LIB_SRC)/surfMesh/lnInclude \ -I$(LIB_SRC)/meshTools/edgeMesh/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude LIB_LIBS = $(LIBS) Code:
make libso meshLibrary wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries: mkdir: das Verzeichnis »/opt/openfoam8/src/meshTools/edgeMesh//lnInclude“ kann nicht angelegt werden: Keine Berechtigung wmakeLnInclude error: failed to create include directory /opt/openfoam8/src/meshTools/edgeMesh//lnInclude g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DUSE_OMP -fopenmp -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -c utilities/meshes/polyMeshGen/polyMeshGen.C -o Make/linux64GccDPInt32Opt/utilities/meshes/polyMeshGen/polyMeshGen.o In file included from lnInclude/meshSubset.H:162, from utilities/meshes/polyMeshGen/polyMeshGenPoints.H:45, from utilities/meshes/polyMeshGen/polyMeshGenFaces.H:40, from utilities/meshes/polyMeshGen/polyMeshGenCells.H:40, from utilities/meshes/polyMeshGen/polyMeshGen.H:39, from utilities/meshes/polyMeshGen/polyMeshGen.C:28: lnInclude/meshSubsetI.H: In member function ‘bool Foam::meshSubset::operator==(const Foam::meshSubset&) const’: lnInclude/meshSubsetI.H:173:18: warning: self-comparison always evaluates to false [-Wtautological-compare] 173 | if( ms.type_ != ms.type_ ) | ~~~~~~~~ ^~ ~~~~~~~~ In file included from utilities/meshes/polyMeshGen/polyMeshGen.C:28: utilities/meshes/polyMeshGen/polyMeshGen.H: At global scope: utilities/meshes/polyMeshGen/polyMeshGen.H:52:9: error: ‘IOdictionary’ does not name a type; did you mean ‘dictionary’? 52 | IOdictionary metaDict_; | ^~~~~~~~~~~~ | dictionary utilities/meshes/polyMeshGen/polyMeshGen.H: In member function ‘const Foam::dictionary& Foam::polyMeshGen::metaData() const’: utilities/meshes/polyMeshGen/polyMeshGen.H:89:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’? 89 | return metaDict_; | ^~~~~~~~~ | metaData utilities/meshes/polyMeshGen/polyMeshGen.H: In member function ‘Foam::dictionary& Foam::polyMeshGen::metaData()’: utilities/meshes/polyMeshGen/polyMeshGen.H:95:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’? 95 | return metaDict_; | ^~~~~~~~~ | metaData utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&)’: utilities/meshes/polyMeshGen/polyMeshGen.C:40:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’ 40 | metaDict_ | ^~~~~~~~~ utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&, const pointField&, const faceList&, const cellList&)’: utilities/meshes/polyMeshGen/polyMeshGen.C:64:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’ 64 | metaDict_ | ^~~~~~~~~ utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&, const pointField&, const faceList&, const cellList&, const wordList&, const labelList&, const labelList&)’: utilities/meshes/polyMeshGen/polyMeshGen.C:100:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’ 100 | metaDict_ | ^~~~~~~~~ utilities/meshes/polyMeshGen/polyMeshGen.C: In member function ‘void Foam::polyMeshGen::write() const’: utilities/meshes/polyMeshGen/polyMeshGen.C:156:5: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’? 156 | metaDict_.writeHeader(fName); | ^~~~~~~~~ | metaData make: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/utilities/meshes/polyMeshGen/polyMeshGen.o] Fehler 1 wmake executables wmake cartesian2DMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird betreten g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -c cartesian2DMesh.C -o Make/linux64GccDPInt32Opt/cartesian2DMesh.o In file included from ../../meshLibrary/lnInclude/meshSubset.H:162, from ../../meshLibrary/lnInclude/polyMeshGenPoints.H:45, from ../../meshLibrary/lnInclude/polyMeshGenFaces.H:40, from ../../meshLibrary/lnInclude/polyMeshGenCells.H:40, from ../../meshLibrary/lnInclude/polyMeshGen.H:39, from ../../meshLibrary/lnInclude/cartesian2DMeshGenerator.H:38, from cartesian2DMesh.C:33: ../../meshLibrary/lnInclude/meshSubsetI.H: In member function ‘bool Foam::meshSubset::operator==(const Foam::meshSubset&) const’: ../../meshLibrary/lnInclude/meshSubsetI.H:173:18: warning: self-comparison always evaluates to false [-Wtautological-compare] 173 | if( ms.type_ != ms.type_ ) | ~~~~~~~~ ^~ ~~~~~~~~ In file included from ../../meshLibrary/lnInclude/cartesian2DMeshGenerator.H:38, from cartesian2DMesh.C:33: ../../meshLibrary/lnInclude/polyMeshGen.H: At global scope: ../../meshLibrary/lnInclude/polyMeshGen.H:52:9: error: ‘IOdictionary’ does not name a type; did you mean ‘dictionary’? 52 | IOdictionary metaDict_; | ^~~~~~~~~~~~ | dictionary ../../meshLibrary/lnInclude/polyMeshGen.H: In member function ‘const Foam::dictionary& Foam::polyMeshGen::metaData() const’: ../../meshLibrary/lnInclude/polyMeshGen.H:89:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’? 89 | return metaDict_; | ^~~~~~~~~ | metaData ../../meshLibrary/lnInclude/polyMeshGen.H: In member function ‘Foam::dictionary& Foam::polyMeshGen::metaData()’: ../../meshLibrary/lnInclude/polyMeshGen.H:95:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’? 95 | return metaDict_; | ^~~~~~~~~ | metaData make[1]: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/cartesian2DMesh.o] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: cartesian2DMesh] Fehler 2 wmake utilities wmake checkSurfaceMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird betreten g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/checkSurfaceMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \ -lmeshTools -ltriSurface -lfiniteVolume -ledgeMesh -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl \ -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh /usr/bin/ld.bfd: -ledgeMesh kann nicht gefunden werden /usr/bin/ld.bfd: -lmeshLibrary kann nicht gefunden werden collect2: error: ld returned 1 exit status make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: checkSurfaceMesh] Fehler 2 If i try "sudo ./Allwmake > log.make 2>&1" this will appear: Code:
./Allwmake: 3: ./Allwmake: wmake: not found ./Allwmake: 6: ./Allwmake: wmake: not found ./Allwmake: 9: ./Allwmake: wmake: not found best regards Kai |
February 15, 2021, 11:57 |
Akash Patel
Rep Power: 7 |
I have uploaded my version here. https://github.com/akashaero/CfMesh-OpenFOAM-8
See if you can compile this one. Regards, Akash
February 15, 2021, 13:07 |
Rep Power: 8 |
Hey Akash,
thank you very much, i downloaded it, copied and run the ./allwmake script. Unfortunatley it didnt work. For example the cartesianMesh command didnt work. Here is the logfile Code:
wmake libso meshLibrary wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries: wmakeLnInclude error: base directory /opt/openfoam8/src/edgeMesh/ does not exist Make/options:17: error: invalid preprocessing directive #Use 17 | # Use the same macro for OpenFOAM.com and OpenFOAM.org | wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file voronoiMeshGenerator.C could not open file labelledPoint.H for source file voronoiMesh/voronoiMeshGenerator/voronoiMeshGenerator.C due to No such file or directory could not open file foamTime.H for source file voronoiMesh/voronoiMeshGenerator/voronoiMeshGenerator.C due to No such file or directory Making dependency list for source file voronoiMeshExtractorCreateMesh.C could not open file foamTime.H for source file voronoiMesh/voronoiMeshExtractor/voronoiMeshExtractorCreateMesh.C due to No such file or directory Making dependency list for source file voronoiMeshExtractorAddressing.C could not open file foamTime.H for source file voronoiMesh/voronoiMeshExtractor/voronoiMeshExtractorAddressing.C due to No such file or directory Making dependency list for source file voronoiMeshExtractor.C could not open file foamTime.H for source file voronoiMesh/voronoiMeshExtractor/voronoiMeshExtractor.C due to No such file or directory Making dependency list for source file tetMeshGenerator.C could not open file labelledPoint.H for source file tetMesh/tetMeshGenerator/tetMeshGenerator.C due to No such file or directory could not open file foamTime.H for source file tetMesh/tetMeshGenerator/tetMeshGenerator.C due to No such file or directory Making dependency list for source file tetMeshExtractorOctree.C could not open file foamTime.H for source file tetMesh/tetMeshExtractorOctree/tetMeshExtractorOctree.C due to No such file or directory Making dependency list for source file cartesian2DMeshGenerator.C could not open file labelledPoint.H for source file cartesian2DMesh/cartesian2DMeshGenerator/cartesian2DMeshGenerator.C due to No such file or directory could not open file foamTime.H for source file cartesian2DMesh/cartesian2DMeshGenerator/cartesian2DMeshGenerator.C due to No such file or directory Making dependency list for source file cartesianMeshGenerator.C could not open file labelledPoint.H for source file cartesianMesh/cartesianMeshGenerator/cartesianMeshGenerator.C due to No such file or directory could not open file foamTime.H for source file cartesianMesh/cartesianMeshGenerator/cartesianMeshGenerator.C due to No such file or directory Making dependency list for source file cartesianMeshExtractorDecomposeSplitHexes.C could not open file foamTime.H for source file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractorDecomposeSplitHexes.C due to No such file or directory Making dependency list for source file cartesianMeshExtractorPolyMesh.C could not open file labelledPair.H for source file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractorPolyMesh.C due to No such file or directory could not open file foamTime.H for source file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractorPolyMesh.C due to No such file or directory Making dependency list for source file cartesianMeshExtractorPointsAndAddressing.C could not open file foamTime.H for source file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractorPointsAndAddressing.C due to No such file or directory Making dependency list for source file cartesianMeshExtractor.C could not open file foamTime.H for source file cartesianMesh/cartesianMeshExtractor/cartesianMeshExtractor.C due to No such file or directory Making dependency list for source file coordinateModifier.C Making dependency list for source file polyMeshGenGeometryModification.C could not open file foamTime.H for source file utilities/anisotropicMeshing/polyMeshGenGeometryModification/polyMeshGenGeometryModification.C due to No such file or directory Making dependency list for source file surfaceMeshGeometryModification.C Making dependency list for source file edgeMeshGeometryModification.C Making dependency list for source file boxScaling.C Making dependency list for source file planeScaling.C Making dependency list for source file newCoordinateModification.C Making dependency list for source file coordinateModification.C make: *** Keine Regel vorhanden, um das Ziel „Make/linux64GccDPInt32Opt/utilities/checkMeshDict/checkMeshDict.C.dep“, benötigt von „Make/linux64GccDPInt32Opt/utilities/checkMeshDict/checkMeshDict.o“, zu erstellen. Schluss. wmake executables wmake cartesian2DMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird betreten Making dependency list for source file cartesian2DMesh.C could not open file foamTime.H for source file cartesian2DMesh.C due to No such file or directory g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -c cartesian2DMesh.C -o Make/linux64GccDPInt32Opt/cartesian2DMesh.o g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/cartesian2DMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \ -lmeshTools -lfiniteVolume -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl \ -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh /usr/bin/ld.bfd: -lmeshLibrary kann nicht gefunden werden collect2: error: ld returned 1 exit status make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: cartesian2DMesh] Fehler 2 wmake utilities wmake checkSurfaceMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird betreten Making dependency list for source file checkSurfaceMesh.C g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -c checkSurfaceMesh.C -o Make/linux64GccDPInt32Opt/checkSurfaceMesh.o g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/checkSurfaceMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \ -lmeshTools -lfiniteVolume -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl \ -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh /usr/bin/ld.bfd: -lmeshLibrary kann nicht gefunden werden collect2: error: ld returned 1 exit status make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: checkSurfaceMesh] Fehler 2 Something occured to me, how is OF8 linked in you "~/bashsrc" file. At mine, its only this line. Code:
source /opt/openfoam8/etc/bashrc Is yours different ? Best regards Kai |
February 15, 2021, 13:24 |
Akash Patel
Rep Power: 7 |
Kai,
I have Openfoam 8 installed from the source in my home directory so mty source path in ~/.bashrc looks like this source ~/OpenFOAM/OpenFOAM-8/etc/bashrc. But I do not think that is what's causing the problem. Can you run al other Openfoam solvers and mesh utilities?
February 15, 2021, 13:48 |
Rep Power: 8 |
Ok, yes all other "native" commands e. g. blockMesh, snappyHexMesh, interFoam are works flawlessly. Best regards Kai
March 1, 2021, 12:13 |
Rep Power: 8 |
its me again. So im going further, on my investigation, but a clue why the installation dont work at all i still dont have. I even tried the Options File from the CfMesh at OpenFoam7, where the installation works flawlessly. I executed the "env" command on my of7 and of8 installation. For my it seems very simular, so i dont realy sees any differents. Maybe the experts do ? Here is the return at OpenFoam7 Code:
of7 SHELL=/bin/bash SESSION_MANAGER=local/Kai-Desktop:@/tmp/.ICE-unix/2217,unix/Kai-Desktop:/tmp/.ICE-unix/2217 WM_COMPILER=Gcc FOAM_SETTINGS= QT_ACCESSIBILITY=1 COLORTERM=truecolor XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg ParaView_INCLUDE_DIR=/opt/paraviewopenfoam56/include/paraview-5.6 XDG_MENU_PREFIX=gnome- GNOME_DESKTOP_SESSION_ID=this-is-deprecated FOAM_MPI=openmpi-system GNOME_SHELL_SESSION_MODE=ubuntu SSH_AUTH_SOCK=/run/user/1000/keyring/ssh ParaView_GL=mesa WM_PRECISION_OPTION=DP WM_PROJECT_USER_DIR=/home/kai/OpenFOAM/kai-7 WM_MPLIB=SYSTEMOPENMPI XMODIFIERS=@im=ibus DESKTOP_SESSION=ubuntu SSH_AGENT_PID=2161 FOAM_RUN=/home/kai/OpenFOAM/kai-7/run FOAM_EXT_LIBBIN=/opt/ThirdParty-7/platforms/linux64GccDPInt32/lib GTK_MODULES=gail:atk-bridge DBUS_STARTER_BUS_TYPE=session PWD=/home/kai/OpenFOAM/kai-7/run/tutorials_of/multiphase/interFoam/laminar/damBreak_stl_II LOGNAME=kai XDG_SESSION_DESKTOP=ubuntu XDG_SESSION_TYPE=x11 WM_OPTIONS=linux64GccDPInt32Opt WM_ARCH=linux64 GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1 ParaView_MAJOR=5.6 XAUTHORITY=/run/user/1000/gdm/Xauthority FOAM_TUTORIALS=/opt/openfoam7/tutorials WM_LABEL_SIZE=32 WM_PROJECT=OpenFOAM WINDOWPATH=2 FOAM_APPBIN=/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin WM_THIRD_PARTY_DIR=/opt/ThirdParty-7 HOME=/home/kai USERNAME=kai IM_CONFIG_PHASE=1 LANG=de_DE.UTF-8 WM_LABEL_OPTION=Int32 WM_CC=gcc LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36: XDG_CURRENT_DESKTOP=ubuntu:GNOME WM_CFLAGS=-m64 -fPIC FOAM_JOB_DIR=/opt/jobControl FOAM_LIBBIN=/opt/openfoam7/platforms/linux64GccDPInt32Opt/lib VTE_VERSION=6003 WM_LINK_LANGUAGE=c++ ParaView_VERSION=5.6.0 ParaView_DIR=/opt/paraviewopenfoam56 GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/f1def7eb_f985_42e9_b0d7_7cf73da69624 FOAM_ETC=/opt/openfoam7/etc INVOCATION_ID=6b44afa063484583a35535b8b8a4ccac MANAGERPID=1956 FOAM_UTILITIES=/opt/openfoam7/applications/utilities FOAM_SITE_LIBBIN=/opt/site/7/platforms/linux64GccDPInt32Opt/lib WM_OSTYPE=POSIX WM_PROJECT_VERSION=7 LESSCLOSE=/usr/bin/lesspipe %s %s XDG_SESSION_CLASS=user WM_DIR=/opt/openfoam7/wmake TERM=xterm-256color FOAM_SITE_APPBIN=/opt/site/7/platforms/linux64GccDPInt32Opt/bin WM_ARCH_OPTION=64 LESSOPEN=| /usr/bin/lesspipe %s USER=kai WM_CXXFLAGS=-m64 -fPIC -std=c++0x MPI_ARCH_PATH=/usr/lib/x86_64-linux-gnu/openmpi WM_PROJECT_INST_DIR=/opt GNOME_TERMINAL_SERVICE=:1.154 FOAM_SRC=/opt/openfoam7/src DISPLAY=:0 SHLVL=1 FOAM_USER_LIBBIN=/home/kai/OpenFOAM/kai-7/platforms/linux64GccDPInt32Opt/lib QT_IM_MODULE=ibus DBUS_STARTER_ADDRESS=unix:path=/run/user/1000/bus,guid=0d2484cc9555a5ea4a237df3602e8aac FOAM_APP=/opt/openfoam7/applications WM_LDFLAGS=-m64 WM_CXX=g++ LD_LIBRARY_PATH=/opt/ThirdParty-7/platforms/linux64Gcc/gperftools-svn/lib:/opt/paraviewopenfoam56/lib/paraview-5.6:/opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/ThirdParty-7/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/kai/OpenFOAM/kai-7/platforms/linux64GccDPInt32Opt/lib:/opt/site/7/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam7/platforms/linux64GccDPInt32Opt/lib:/opt/ThirdParty-7/platforms/linux64GccDPInt32/lib:/opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/dummy XDG_RUNTIME_DIR=/run/user/1000 WM_COMPILE_OPTION=Opt FOAM_INST_DIR=/opt MPI_BUFFER_SIZE=20000000 JOURNAL_STREAM=9:46863 FOAM_SOLVERS=/opt/openfoam7/applications/solvers WM_PROJECT_DIR=/opt/openfoam7 WM_COMPILER_TYPE=system XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop FOAM_USER_APPBIN=/home/kai/OpenFOAM/kai-7/platforms/linux64GccDPInt32Opt/bin PATH=/opt/ThirdParty-7/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam56/bin:/home/kai/OpenFOAM/kai-7/platforms/linux64GccDPInt32Opt/bin:/opt/site/7/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam7/bin:/opt/openfoam7/wmake:/home/kai/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin PV_PLUGIN_PATH=/opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/paraview-5.6 GDMSESSION=ubuntu WM_COMPILER_LIB_ARCH=64 FOAM_SIGFPE= DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus,guid=0d2484cc9555a5ea4a237df3602e8aac _=/usr/bin/env Code:
of8 SHELL=/bin/bash SESSION_MANAGER=local/Kai-Desktop:@/tmp/.ICE-unix/2217,unix/Kai-Desktop:/tmp/.ICE-unix/2217 WM_COMPILER=Gcc FOAM_SETTINGS= QT_ACCESSIBILITY=1 COLORTERM=truecolor XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg ParaView_INCLUDE_DIR=/opt/paraviewopenfoam56/include/paraview-5.6 XDG_MENU_PREFIX=gnome- GNOME_DESKTOP_SESSION_ID=this-is-deprecated FOAM_MPI=openmpi-system GNOME_SHELL_SESSION_MODE=ubuntu SSH_AUTH_SOCK=/run/user/1000/keyring/ssh ParaView_GL=mesa WM_PRECISION_OPTION=DP WM_PROJECT_USER_DIR=/home/kai/OpenFOAM/kai-8 WM_MPLIB=SYSTEMOPENMPI XMODIFIERS=@im=ibus DESKTOP_SESSION=ubuntu SSH_AGENT_PID=2161 FOAM_RUN=/home/kai/OpenFOAM/kai-8/run FOAM_EXT_LIBBIN=/opt/ThirdParty-8/platforms/linux64GccDPInt32/lib GTK_MODULES=gail:atk-bridge DBUS_STARTER_BUS_TYPE=session PWD=/home/kai/OpenFOAM/kai-8/run/multiphase/interFoam/laminar/damBreak LOGNAME=kai XDG_SESSION_DESKTOP=ubuntu XDG_SESSION_TYPE=x11 WM_OPTIONS=linux64GccDPInt32Opt WM_ARCH=linux64 GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1 ParaView_LIB_DIR=/opt/paraviewopenfoam56/lib ParaView_MAJOR=5.6 XAUTHORITY=/run/user/1000/gdm/Xauthority FOAM_TUTORIALS=/opt/openfoam8/tutorials WM_LABEL_SIZE=32 WM_PROJECT=OpenFOAM WINDOWPATH=2 FOAM_APPBIN=/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin WM_THIRD_PARTY_DIR=/opt/ThirdParty-8 HOME=/home/kai USERNAME=kai IM_CONFIG_PHASE=1 LANG=de_DE.UTF-8 WM_LABEL_OPTION=Int32 WM_CC=gcc LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36: XDG_CURRENT_DESKTOP=ubuntu:GNOME WM_CFLAGS=-m64 -fPIC FOAM_JOB_DIR=/opt/jobControl FOAM_LIBBIN=/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib VTE_VERSION=6003 WM_LINK_LANGUAGE=c++ ParaView_VERSION=5.6.0 ParaView_DIR=/opt/paraviewopenfoam56 GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/7a617517_9f98_4e78_a5a2_dc7bdbd8ff09 FOAM_ETC=/opt/openfoam8/etc INVOCATION_ID=6b44afa063484583a35535b8b8a4ccac MANAGERPID=1956 FOAM_UTILITIES=/opt/openfoam8/applications/utilities FOAM_SITE_LIBBIN=/opt/site/8/platforms/linux64GccDPInt32Opt/lib WM_OSTYPE=POSIX WM_PROJECT_VERSION=8 LESSCLOSE=/usr/bin/lesspipe %s %s XDG_SESSION_CLASS=user WM_DIR=/opt/openfoam8/wmake TERM=xterm-256color FOAM_SITE_APPBIN=/opt/site/8/platforms/linux64GccDPInt32Opt/bin WM_ARCH_OPTION=64 LESSOPEN=| /usr/bin/lesspipe %s USER=kai WM_CXXFLAGS=-m64 -fPIC -std=c++0x MPI_ARCH_PATH=/usr/lib/x86_64-linux-gnu/openmpi WM_PROJECT_INST_DIR=/opt GNOME_TERMINAL_SERVICE=:1.159 FOAM_SRC=/opt/openfoam8/src DISPLAY=:0 SHLVL=1 FOAM_USER_LIBBIN=/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib QT_IM_MODULE=ibus DBUS_STARTER_ADDRESS=unix:path=/run/user/1000/bus,guid=0d2484cc9555a5ea4a237df3602e8aac FOAM_APP=/opt/openfoam8/applications WM_LDFLAGS=-m64 WM_CXX=g++ LD_LIBRARY_PATH=/opt/ThirdParty-8/platforms/linux64Gcc/gperftools-svn/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/paraview-5.6:/opt/paraviewopenfoam56/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/ThirdParty-8/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib:/opt/site/8/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib:/opt/ThirdParty-8/platforms/linux64GccDPInt32/lib:/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/dummy XDG_RUNTIME_DIR=/run/user/1000 WM_COMPILE_OPTION=Opt FOAM_INST_DIR=/opt MPI_BUFFER_SIZE=20000000 JOURNAL_STREAM=9:46863 FOAM_SOLVERS=/opt/openfoam8/applications/solvers WM_PROJECT_DIR=/opt/openfoam8 WM_COMPILER_TYPE=system XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop FOAM_USER_APPBIN=/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin PATH=/opt/ThirdParty-8/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam56/bin:/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin:/opt/site/8/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin:/opt/openfoam8/bin:/opt/openfoam8/wmake:/home/kai/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin PV_PLUGIN_PATH=/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/paraview-5.6 GDMSESSION=ubuntu WM_COMPILER_LIB_ARCH=64 FOAM_SIGFPE= DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus,guid=0d2484cc9555a5ea4a237df3602e8aac _=/usr/bin/env Is there any note why the isntallation dont work problably. Best regards Kai |
April 6, 2021, 17:17 |
CfMesh compatible with OpenFOAM 8
Akash Patel
Rep Power: 7 |
It looks like someone is maintaining an updated fork for CfMesh which is compatible with OpenFOAM 8.0. Try this and see if this works
https://sourceforge.net/p/cfmesh-cfd...i/master/tree/
April 10, 2021, 11:14 |
#11 |
Rep Power: 8 |
Thank you for that information. It dosent work at my computer.
When i do "./Allwmake > log.make 2>&1", i will get this message: Code:
wmake libso meshLibrary wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries: wmakeLnInclude error: base directory /opt/openfoam8/src/edgeMesh/ does not exist wmake executables wmake cartesian2DMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfmesh/executables/cartesian2DMesh“ wird betreten g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_VERSION_6 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/cartesian2DMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \ -ltriSurface -lmeshTools -lmeshLibrary -lOpenFOAM -ldl \ -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::dictionary::dictionary(Foam::Istream&)' /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::Ostream::write(Foam::keyType const&)' /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::UOPstream::write(Foam::token const&)' collect2: error: ld returned 1 exit status make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfmesh/executables/cartesian2DMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: cartesian2DMesh] Fehler 2 wmake utilities wmake checkSurfaceMesh make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfmesh/utilities/checkSurfaceMesh“ wird betreten g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_VERSION_6 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/checkSurfaceMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \ -ltriSurface -lmeshTools -lmeshLibrary -lOpenFOAM -ldl \ -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::dictionary::dictionary(Foam::Istream&)' /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::Ostream::write(Foam::keyType const&)' /usr/bin/ld.bfd: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib/libmeshLibrary.so: undefined reference to `Foam::UOPstream::write(Foam::token const&)' collect2: error: ld returned 1 exit status make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Fehler 1 make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfmesh/utilities/checkSurfaceMesh“ wird verlassen make: *** [/opt/openfoam8/wmake/makefiles/apps:39: checkSurfaceMesh] Fehler 2 |
April 10, 2021, 14:27 |
#12 |
Rep Power: 12 |
as a test, I have
1. tried to compile the version above in the github link on OpenFOAM 8 installation, no success. It did not compiled at all. 2. tried to compile the version above in the sourceforge link on OpenFOAM 8 installation. It did compiled but many features are not working such as pMesh, tetMesh. cartesianMesh seems working though... |
cfmesh, mesh, meshing, openfoam, openfoam 8 |
[cfMesh] cfMesh - OpenFOAM v1812 not working in parallel | codygo | OpenFOAM Community Contributions | 1 | May 3, 2019 06:22 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
