[openFuelCell] Simulate a PEM fuel cell using openfuelcell
Old   June 21, 2021, 09:02
Default Simulate a PEM fuel cell using openfuelcell
Ren J.
Ren_J is on a distinguished road
I installed OpenFOAM-v1706 and openfuelcell on Ubuntu 14.04. I’m trying to run a tutorial case. I firstly type “make mesh”. Then try “make run” or “make srun”, I got an error like this. IMG_2921.jpg
Ren_J is offline   Reply With Quote
Old   June 21, 2021, 09:06
Ren J.
The error is:
Make srun
/bin/sh: 1: fuelCellFoam: not found
Make run
/bin/sh: 1: ./prun: not found
Old   September 7, 2021, 12:09
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
Originally Posted by Ren_J View Post
The error is:
Make srun
Make run
You can try in OpenFOAM4.0?
ramakant is offline   Reply With Quote
Old   September 7, 2021, 17:15
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello Ren J.
As Ramakant mentions using version 4.0 would probably help as the openFuelCell code is developed for the foundation fork of openFoam to my knowledge.
https://openfuelcell.sourceforge.io/doc/prerequisites
I believe the current code available works for version 4.0 or 6.0, if not get back to me and I'll update it to 6.0 if necessary.
This is also evident from your first error code as it doesn't know what the solver called is: fuelCellFoam: not found
Regards Lasse
Swagga5aur is offline   Reply With Quote
PEM fuel cell modeling alimech Main CFD Forum 4 April 18, 2020 14:15
Segmentation Fault on PEM fuel cell addon Adam404 Fluent UDF and Scheme Programming 13 June 18, 2019 02:22
simulate fuel cell with fire shahrbanoo AVL FIRE 1 September 1, 2013 22:25
PEM fuel cell karmagos FLUENT 1 May 4, 2012 20:28
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
