[swak4Foam] Swak4foam
Old   September 19, 2021, 17:50
Default Swak4foam
User User
Usern is on a distinguished road
Hello, can i please ask you a question regarding this error encountered in the installation of swak4foam on Ubuntu 18.04 version.
This script is rather crude.
If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh).
Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/user/OpenFOAM/OpenFOAM-5.x/swak4Foam/privateRequirements/bin to PATH-variable.
The ./Allwmake-script will use this directory automatically Environment variable WM_PROJECT_VERSION unset This means that no OpenFOAM version is actived Please activate the OF for which you want to compile swak4Foam
PS: I added this to ~/.bashrc
source /home/user/OpenFOAM/OpenFOAM-5.x/etc/bashrc
export WM_PROJECT_VERSION=5.x
export PATH="/home/user/OpenFOAM/OpenFOAM-5.x/swak4Foam/privateRequirements/bin:$PATH" alias
of5='source /home/user/OpenFOAM/OpenFOAM-5.x/etc/bashrc' and i added this to the bashrc file of OpenFOAM.
I am new to linux. How can i solve it ?
Thank you,
Usern is offline   Reply With Quote
Old   September 29, 2022, 22:54
Na
MontelukastNa is on a distinguished road
hello,Usern,did you solve this problem?
MontelukastNa is offline   Reply With Quote
OpenFoam Case crashes using swak4Foam Miguel.Mendez Main CFD Forum 2 March 24, 2021 00:42
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 12:59
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 11:31
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 18:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 14:00
