-   OpenFOAM Community Contributions (https://www.cfd-online.com/Forums/openfoam-community-contributions/)
-   -   [waves2Foam] Compilation of waves2FoamMooring on OF-1912 (https://www.cfd-online.com/Forums/openfoam-community-contributions/238870-compilation-waves2foammooring-1912-a.html)
cesa October 7, 2021 14:12
Hello everyone,
I'm trying to compile the tool waves2FoamMooring on OF1912, but I can't. This is the error output:
write1DFvMesh/write1DFvMesh.C: In member function ‘void Foam::write1DFvMesh::updateMesh(const Foam::List<Foam::Field<Foam::Vector<double> > >&, const labelList&, const labelList&, const labelList&, const labelList&)’:
write1DFvMesh/write1DFvMesh.C:225:9: error: ‘Xfer’ was not declared in this scope
Xfer<pointField> xpp;
write1DFvMesh/write1DFvMesh.C:225:24: error: expected primary-expression before ‘>’ token
write1DFvMesh/write1DFvMesh.C:225:26: error: ‘xpp’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:225:26: note: suggested alternative: ‘lpp’
lpp
write1DFvMesh/write1DFvMesh.C:231:22: error: expected primary-expression before ‘>’ token
Xfer<faceList> xfaces;
write1DFvMesh/write1DFvMesh.C:231:24: error: ‘xfaces’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:231:24: note: suggested alternative: ‘face’
face
write1DFvMesh/write1DFvMesh.C:280:22: error: expected primary-expression before ‘>’ token
Xfer<cellList> xcells;
write1DFvMesh/write1DFvMesh.C:280:24: error: ‘xcells’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:280:24: note: suggested alternative: ‘cell’
cell
make: *** [/home/carlos/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/write1DFvMesh/write1DFvMesh.o] Error 1
It looks like the Xfer function disappeared from OF-v1912, although users can find it in OF-v1712. Is there any way of compiling this utility on OpenFOAM v1912?
Best regards,
Carlos
ngj October 7, 2021 17:46
Hi Carlos,
I am pretty sure that it can be compiled, but you most likely need to dive into the code and correct for the changes in syntax.
Kind regards
Niels
