[swak4Foam] How to even start swak4foam cases
Old   November 5, 2017, 09:26
Default How to even start swak4foam cases
mabubel is on a distinguished road
I just set up my first simulation with Openfoam 1706+ docker image and imported geometries from Salome. Works so far.
Next I would like to run swak4foam examples to try groovybc. I installed the docker container and copied pulsedpitzdaily to my home folder.
The tutorial says the next step would be to run blochMesh, which works. I had a look into the system folder and this example seems to use pisoFoam so I started pisoFoam which leads to an error message about a missing turbulenceProperties file. As there is a turbulenceProperties.template file I guess pisoFoam is the wrong command.
I could not find a source on how to use swak4foam that describes the command I need to use. Any ideas?
kinder regards,
Mabubel
mabubel is offline   Reply With Quote
Old   November 5, 2017, 12:17
the next thing I tried (found it here: http://openfoamwiki.net/index.php/Contrib/PyFoam) was pyfoamrunner.py:
[me@799b435714a2 pulsedPitzDaily]$ pyFoamRunner.py pisoFoam
 Reading regular expressions from /home/me/OpenFOAM/pulsedPitzDaily/customRegexp
 PyFoam WARNING on line 42 of file /usr/lib/python2.7/site-packages/PyFoam/Infrastructure/ServerBase.py : No certficate file /home/me/.pyFoam/foamServerCertificate.cert exists. Therefor no SSL-connection for the FoamServer possible
 To generate a private key:
    openssl genrsa -out /home/me/.pyFoam/foamServerCertificate.key 2048
Then generate the cerificate that is valid for 3 years with
    openssl req -new -x509 -key /home/me/.pyFoam/foamServerCertificate.key -out /home/me/.pyFoam/foamServerCertificate.cert -days 1095
|  \\    /   O peration     | Version:  v1706                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : v1706
Arch   : "LSB;label=32;scalar=64"
Exec   : pisoFoam
Date   : Nov 05 2017
Time   : 14:34:57
Host   : "799b435714a2"
PID    : 355
Case   : /home/me/OpenFOAM/pulsedPitzDaily
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
    From function void* Foam::dlOpen(const Foam::fileName&, bool)
    in file POSIX.C at line 1321
    dlopen error : libswakPythonIntegration.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 101
    could not load "libswakPythonIntegration.so"
profiling initialized
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/me/OpenFOAM/pulsedPitzDaily/constant/turbulenceProperties at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 237.
FOAM exiting
But it did not work either.
Old   January 31, 2022, 19:13
Sung Kwon
sungmin130 is on a distinguished road
I am having a same problem Did you figure out how to do it? Thanks in advance.
sungmin130 is offline   Reply With Quote
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
simpleFoam crushes at 1st Time loop. seav OpenFOAM Running, Solving & CFD 18 June 4, 2013 08:18
Is OpenFOAM tutorial cases valid? j-avdeev OpenFOAM Running, Solving & CFD 3 September 19, 2012 15:45
on the definition of Start in shell autoignition mepgzzi Siemens 0 June 18, 2008 10:33
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 22:55
