[PyFoam] PyFoam Installation Problems
Old   March 18, 2022, 15:53
Default PyFoam Installation Problems
Nolan Dyck
njdyck is on a distinguished road
Hi, I have installed PyFoam version 2021.6 using pip on Ubuntu 20.04.4 LTS.
The only wrinkle I encountered so far was that my system installed the scripts at $HOME/.local/bin instead of /usr/local/bin. I solved this by adding it to my path in ~/.bashrc.
It recognizes OpenFOAM v8 when I run pyFoamVersion.py
I copied the tutorial case $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity into $HOME, constructed the mesh, and ran icoFoam to confirm the case was setup properly.
Then I executed:
username@DESKTOP-7R3L17E:~/cavity$ pyFoamPlotRunner.py --clear --progress --auto auto
Clearing out old timesteps ....
 Warning in /home/username/.local/bin/pyFoamPlotRunner.py : Replacing solver 'auto' with icoFoam in arguments
 PyFoam WARNING on line 37 of file /home/username/.local/lib/python3.8/site-packages/PyFoam/Infrastructure/ServerBase.py : No certficate file /home/username/.pyFoam/foamServerCertificate.cert exists. Therefor no SSL-connection for the FoamServer possible
 To generate a private key:
    openssl genrsa -out /home/username/.pyFoam/foamServerCertificate.key 2048
Then generate the cerificate that is valid for 3 years with
    openssl req -new -x509 -key /home/username/.pyFoam/foamServerCertificate.key -out /home/username/.pyFoam/foamServerCertificate.cert -days 1095
Traceback (most recent call last):
  File "/home/username/.local/bin/pyFoamPlotRunner.py", line 5, in <module>
    PlotRunner()
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Applications/PlotRunner.py", line 65, in __init__
    PyFoamApplication.__init__(self,
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Applications/PyFoamApplication.py", line 496, in __init__
    result=self.run()
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Applications/PlotRunner.py", line 122, in run
    run=GnuplotRunner(argv=self.replaceAutoInArgs(self.parser.getArgs()),
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Execution/GnuplotRunner.py", line 197, in __init__
    GnuplotCommon.__init__(self,
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Execution/GnuplotRunner.py", line 67, in __init__
    self.createPlots(persist=persist,
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Execution/AnalyzedCommon.py", line 261, in createPlots
    plots["linear"]=createPlotTimelinesDirect("linear",
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Basics/PlotTimelinesFactory.py", line 105, in createPlotTimelinesDirect
    return createPlotTimelines(timelines,ci,
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Basics/PlotTimelinesFactory.py", line 56, in createPlotTimelines
    return lookupTable[implementation](timelines,
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/Basics/GnuplotTimelines.py", line 43, in __init__
    Gnuplot.__init__(self, persist=self.spec.persist, quiet=quiet)
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/_Gnuplot.py", line 179, in __init__
    self.gnuplot = gp.GnuplotProcess(persist=persist, quiet=quiet)
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/gp_unix.py", line 189, in __init__
    if not test_persist():
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/gp_unix.py", line 136, in test_persist
    (not response) or (string.find(response[0], '-persist') == -1))
AttributeError: module 'string' has no attribute 'find'
Exception ignored in: <function GnuplotProcess.__del__ at 0x7fefe30b9430>
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/gp_unix.py", line 214, in __del__
    self.close()
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/gp_unix.py", line 209, in close
    if self.gnuplot is not None:
AttributeError: 'GnuplotProcess' object has no attribute 'gnuplot'
Exception ignored in: <function Gnuplot.__del__ at 0x7fefc2527af0>
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/_Gnuplot.py", line 200, in __del__
  File "/home/username/.local/lib/python3.8/site-packages/PyFoam/ThirdParty/Gnuplot/_Gnuplot.py", line 195, in close
AttributeError: 'GnuplotTimelines' object has no attribute 'gnuplot'
username@DESKTOP-7R3L17E:~/cavity$ ls
0  Gnuplotting.analyzed  PyFoamServer.info  cavity.foam  constant  system
username@DESKTOP-7R3L17E:~/cavity$ vi PyFoamServer.info
Any help would be appreciated!
njdyck is offline   Reply With Quote
openfoam 8, pyfoam installation
[PyFoam] Problems with installing PyFoam Christoph_84 OpenFOAM Community Contributions 34 October 26, 2021 11:25
[OpenFOAM.com] v1606+ Problems of installation on iMac Intercooled OpenFOAM Installation 4 November 15, 2016 20:22
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) immortality Lounge 2 May 24, 2014 03:05
Problems with installation batta31 OpenFOAM Installation 2 September 4, 2012 07:01
installation problems on upgrade from win 3.26 to mic Siemens 5 June 20, 2007 09:40
