[Other] [fluidfoam] python package to read and plot OpenFoam data
Like Tree10Likes
  • 8 Post By cyss38
  • 1 Post By Edgar Alejandro Martínez
  • 1 Post By cyss38
Old   March 1, 2020, 18:06
Smile [fluidfoam] python package to read and plot OpenFoam data
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
Dear all,
The fluidfoam package (https://github.com/fluiddyn/fluidfoam) provides useful Python classes for easily reading and manipulating OpenFoam output files.
You can find some examples here : https://fluidfoam.readthedocs.io/en/...les/index.html
fluidfoam is also used to read 1D simulation outputs and put them in swak4foam format in order to use 1D data for boundary conditions and / or initial fields : https://fluidfoam.readthedocs.io/en/...cessing1d.html. (Today there is no example on this subject in the example gallery... Coming soon)
Best,
Cyrille
PS : fluidfoam is available with pip, conda or via sources from github:
gschaider, snak, salehi144 and 5 others like this.
cyss38 is offline   Reply With Quote
Old   September 15, 2021, 16:10
Edgar Alejandro Martínez Ojeda
Edgar Alejandro Martínez is on a distinguished road
I have an example from a 2D actuator turbine. You can learn how to get the coordinates as well as the desired fields: https://www.youtube.com/watch?v=wFZeFDUQflQ
cyss38 likes this.
Edgar Alejandro Martínez is offline   Reply With Quote
Old   September 15, 2021, 18:25
cyss38's Avatar
Cyrille Bonamy
Thanks you very much for this tutorial
You say that the structured option of readMesh does not work in your case.
Can you send me your blockMeshDict file to solve this issue?
The best is to open an issue on the official github repository (but the blockMeshDict may be enough )
Old   September 15, 2021, 20:52
I meant I had to set the option to False. I don't know what "structured mesh" means to fluidfoam. Remember that meshes generated by blockMesh are not exactly structured since every node has an ID. So blockMesh is not structured eventhough it is rectangular.
Here's my blockMeshDict, this is another similar mesh though:
| \\ / O peration | Version: dev |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
vertices
( -60 -60 -1)
( 100 -60 -1)
( 100 60 -1)
( -60 60 -1)
( -60 -60 1)
( 100 -60 1)
( 100 60 1)
( -60 60 1)
blocks
hex (0 1 2 3 4 5 6 7) (240 180 1) simpleGrading (1 1 1)
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(2 6 5 1)
top
type patch;
faces
(3 7 6 2)
bottom
type patch;
faces
(1 5 4 0)
back
type empty;
faces
(0 3 2 1)
front
type empty;
faces
(6 7 4 5)
Old   September 16, 2021, 04:05
cyss38's Avatar
Cyrille Bonamy
Ok, I tested it. Indeed in this case there is a problem of precision. I don't know exactly why but there are accuracy problems in the openfoam files (generated by blockMesh).
It's not a problem but when fluidfoam/python looks for the unique values of the center of the cells for a given direction (x for example), there are cases where it doesn't work well (for 2 different y, you can have a very slightly different x when it should be constant).
To avoid this problem, there is the "precision" option in fluidfoam (the default value is 15).
In your case, :
x, y, z = readmesh(sol, True, precision = 14)
One of the interests of using structured=True is not to have to know nx, ny, nz. fluidfoam calculates them and we can easily find them :
nx, ny, nz = np.shape(x)
Old   March 29, 2022, 10:04
FluentStarter is on a distinguished road
Late, but I guess it is newer too late to say thanks. Nice and helpful package!
FluentStarter is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[General] How to plot two sets of data on same axis czhe ParaView 0 June 16, 2016 15:10
[General] Contour plot: celldata2pointdata dmaz ParaView 1 April 28, 2014 16:05
Convergence Problem - Read convergence data rafacerq FLUENT 0 January 31, 2014 10:47
How to read .txt data used by sampleDict? kiddmax OpenFOAM Post-Processing 3 October 11, 2013 18:14
