[Tutorials] Parametric propeller tutorial
Like Tree3Likes
  • 3 Post By linnemann
Old   March 28, 2016, 14:30
Default Parametric propeller tutorial
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hello
I hereby give you a parametric propeller tutorial using AMI's and pimpleDyMFoam.
All the parameters of the 3D propeller geometry can be set in the Mesh/SalomeGeometry.py file.
github link
I use simple skew angle, pitch angle and coord scaling to obtain a propeller.
those are set using control points on a line and those lines can be modified as desired.
This could be extended to use the Wageningen B-Series description of propellers, but that is not nearly as flexible as this method.
You can generate your own profiles using Xfoil and export them into txt file using the psav command.
The geometry generation should be fairly robust, although i have not tested all facets.
Tobi, dupeng and gabrielfelix like this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 24, 2016, 10:14
Aldias Bahatmaka
bmaldi is on a distinguished road
Originally Posted by linnemann View Post
Hello
github link
Hello Mr.Niels,
Thanks so much for your posting!
But the Salome is free for user or not?
because i'm student and maybe difficult if i should buy the license..
So that why i need some guide from you,
Thanks so much.
Best Regards,
Aldi
bmaldi is offline   Reply With Quote
Old   April 24, 2016, 10:59
linnemann's Avatar
Niels Nielsen
go to www.salome-platform.org
Linnemann
Old   April 24, 2016, 22:27
Aldias Bahatmaka
Actually i already have Salome Meca V2015_2. Is it different?
Old   May 2, 2016, 01:53
Aldias Bahatmaka
Hello
github link
Hello Mr.Linnemann,
I tried to use Salome,
when the mesh processing, it was error,.
http://www.cfd-online.com/Forums/ope...ca-2015-a.html
need your help.
thanks a lot
Old   March 5, 2022, 13:37
Default VAWT configuration
djason is on a distinguished road
Hello Mr.Linnemann
I was able to get this to run. Would it be easy enough to transpose the geometry in this setup to use it for a vertical axis wind turbine simulation?
djason is offline   Reply With Quote
Old   June 7, 2022, 09:52
Michael Jensen
mikethe1wheelnut is on a distinguished road
Hello
github link
Broken link.
mikethe1wheelnut is offline   Reply With Quote
Old   June 7, 2022, 12:49
I was able to make the transposition. I will post it here soon
uniformValue table meaning in propeller tutorial donQi OpenFOAM Running, Solving & CFD 12 November 3, 2022 07:54
pimpleDyMFoa, propeller tutorial. Why correctPhi no? be_inspired OpenFOAM Running, Solving & CFD 1 April 16, 2022 08:49
Fluent Propeller Simulation NGH FLUENT 6 May 14, 2018 00:16
propeller tutorial using AMI in OF v2.1.0 impecca OpenFOAM Pre-Processing 6 May 9, 2016 10:22
propeller tutorial openfoam_user OpenFOAM Running, Solving & CFD 0 February 8, 2012 04:02
