March 28, 2016, 14:30 |
Parametric propeller tutorial
Niels Nielsen
Rep Power: 27 |
Hello
I hereby give you a parametric propeller tutorial using AMI's and pimpleDyMFoam. All the parameters of the 3D propeller geometry can be set in the Mesh/SalomeGeometry.py file. github link I use simple skew angle, pitch angle and coord scaling to obtain a propeller. those are set using control points on a line and those lines can be modified as desired. This could be extended to use the Wageningen B-Series description of propellers, but that is not nearly as flexible as this method. You can generate your own profiles using Xfoil and export them into txt file using the psav command. The geometry generation should be fairly robust, although i have not tested all facets.
Linnemann PS. I do not do personal support, so please post in the forums. Last edited by linnemann; March 29, 2016 at 03:36. |
April 24, 2016, 10:14 |
#2 | |
Aldias Bahatmaka
Rep Power: 10 |
Thanks so much for your posting! But the Salome is free for user or not? because i'm student and maybe difficult if i should buy the license.. So that why i need some guide from you, Thanks so much. Best Regards, Aldi |
April 24, 2016, 10:59 |
Niels Nielsen
Rep Power: 27 |
go to www.salome-platform.org
Linnemann PS. I do not do personal support, so please post in the forums. |
April 24, 2016, 22:27 |
#4 | |
Aldias Bahatmaka
Rep Power: 10 |
May 2, 2016, 01:53 |
#5 | |
Aldias Bahatmaka
Rep Power: 10 |
I tried to use Salome, when the mesh processing, it was error,. http://www.cfd-online.com/Forums/ope...ca-2015-a.html need your help. thanks a lot |
March 5, 2022, 13:37 |
VAWT configuration
Rep Power: 8 |
Hello Mr.Linnemann
I was able to get this to run. Would it be easy enough to transpose the geometry in this setup to use it for a vertical axis wind turbine simulation? |
June 7, 2022, 09:52 |
#7 | |
Michael Jensen
Rep Power: 3 |
Broken link. |
June 7, 2022, 12:49 |
Rep Power: 8 |
I was able to make the transposition. I will post it here soon
uniformValue table meaning in propeller tutorial | donQi | OpenFOAM Running, Solving & CFD | 12 | November 3, 2022 07:54 |
pimpleDyMFoa, propeller tutorial. Why correctPhi no? | be_inspired | OpenFOAM Running, Solving & CFD | 1 | April 16, 2022 08:49 |
Fluent Propeller Simulation | NGH | FLUENT | 6 | May 14, 2018 00:16 |
propeller tutorial using AMI in OF v2.1.0 | impecca | OpenFOAM Pre-Processing | 6 | May 9, 2016 10:22 |
propeller tutorial | openfoam_user | OpenFOAM Running, Solving & CFD | 0 | February 8, 2012 04:02 |
