June 15, 2022, 16:29
Having trouble compiling swak4Foam
Hello!
I am trying to compile swak4Foam and facing some problems. I couldn't find a way to fix it. here is the output of the make. Any ideas how to fix this? Thanks.
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
Bison already installed/compiled
Bison successfully compiled
Lua already installed/compiled
Lua successfully compiled
Add /home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically
Current OpenFOAM version is v2006.
Previously compiled for OpenFOAM (v2006)
/home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Reading variables from 'swakConfiguration'
Looking for Python 2
Found Python 2.7
Configuring Python 2.7
Using python2.7 at /usr/bin/python2.7-config for python2
Looking for Python 3
Found Python 3.8
Configuring Python 3.8
Using python3.8 at /usr/local/packages/python/3.8.5-anaconda/bin/python3.8-config for python3
Using our own Lua at /home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/privateRequirements
Checking swak4Foam-version and generating file
Swak version is 2021.05.0
hg info: af74ec7e1714+
Using /home/nazari/tools/bin/bear to build compilation database
Bison: /home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/privateRequirements/bin/bison
Flex: /usr/bin/flex
Bison at /home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4)
Flex is version 2.5.37 (Minor version: 37)
OpenFOAM-version: Major 2006 Minor 0 Patch 0 (-1 == x / 0) Fork: com
No change to swak4FoamParsers/foamVersion4swak.H
Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem
wmake libso swak4FoamParsers
/home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:38: /home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../../../rules/versionOptions: No such file or directory
/home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:48: /home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../mybison: No such file or directory
/home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/options:49: /home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory
make: *** No rule to make target `/home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop.
wmake error: file '/home/nazari/openfoam/OpenFOAM-v2006/build/linux64GccDPInt32Opt/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /home/nazari/openfoam/OpenFOAM-v2006/swak4Foam/Libraries/swak4FoamParsers
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard
