[Tutorials] Speech-driven airflow (including turbulence, particle motion, downstream inhalation)
Old   February 11, 2025, 20:52
Default Speech-driven airflow (including turbulence, particle motion, downstream inhalation)
Nick Howlett
nhowlett is on a distinguished road
I'm investigating a flow scenario related to public health, in particular possible innovations around PPE.
Basically it simulates the scenario of an virus-infected person transmitting bioaerosols when 'speaking' while another person is 'listening' at 1 metre away. This 2nd person is wearing a face shield, while breathing normally thru only their nose.
The full OpenFOAM simulation files for a 3D LES computation is available on my GitHub for reuse and collaboration [1]! Although we're using some serious computing power for the transient (time-stepping) approach (20 CPU cores per simulation), you could possibly get away using significantly less cores as we can do a single simulation in ~ 5 hours (we deemed the flow behaviour is asymptotic at ~ 45 flow-time secs) if you relax the convergence criteria away from standard values (we're interested in innovation applications primarily, not in extremely high accuracy of the fluid dynamics).
[1] https://github.com/TessellateDataSci...dOptimisations
If you have any difficulty understanding anything please reply in this thread so we can do some better instructional design. Thanks!
Last edited by nhowlett; February 28, 2025 at 00:11. Reason: Correcting computing (real) time advice.
nhowlett is offline   Reply With Quote
Old   March 28, 2025, 01:46
Nick Howlett
Originally Posted by nhowlett View Post
Although we're using some serious computing power for the transient (time-stepping) approach (20 CPU cores per simulation), you could possibly get away using significantly less cores as we can do a single simulation in ~ 5 hours.
Seems I was quite wrong about scaling across processors. I checked and you can probably do a simulation for the flow-time of 45 secs in ~ 12 hours using only 4 cores.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
How to use MPPICFoam with turbulence effects on particle motion? mneben OpenFOAM Running, Solving & CFD 23 May 23, 2018 23:40
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
