[swak4Foam] installing funkySetFields
Old   March 20, 2009, 01:40
Default installing funkySetFields
Prapanch Nair
prapanj is on a distinguished road
I downloaded the tar.gz file "funkySetFields.r7106". I extracted the file to $FOAM_APP/utilities/preProcessing/ . For clarity let me call the above path as $PREPROCESS.
$PREPROCESS/funkySetFields/ has a .C file, a Dict file, valueexpressiondriv.c, h etc.
I ran wmake in $PREROCESS/funkySetFields, and got the error "myflex no rule to make target. So I copied the mybison and myflex files to $PREPROCESS/funkySetFields from the Make folder.
I edited the options file. I modified the lines "include $(MAKE_DIR)/mybison" & "include $(MAKE_DIR)/myflex" to "include mybison" and "include myflex".
again ran wmake. This is the error I am getting:
SOURCE=ValueExpressionParser.yy ; rm Make/linuxGccDPOpt/ValueExpressionParser.C Make/linuxGccDPOpt/ValueExpressionParser.tab.hh; bison -ra -S lalr1.cc -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/ValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/ValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/rwdi/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/rwdi/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -IlnInclude -I. -I/home/rwdi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rwdi/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/ValueExpressionParser.C -o Make/linuxGccDPOpt/ValueExpressionParser.o
ValueExpressionParser.tab.cc: In member function ‘virtual int ve::ValueExpressionParser:arse()’:
ValueExpressionParser.tab.cc:425: error: cannot convert ‘ve::ValueExpressionParser::semantic_type*’ to ‘YYSTYPE*’ for argument ‘1’ to ‘int velex(YYSTYPE*, yy::location*, ValueExpressionDriver&)’
ValueExpressionParser.tab.cc: In member function ‘unsigned char ve::ValueExpressionParser::yytranslate_(int)’:
ValueExpressionParser.tab.cc:1788: warning: use of old-style cast
ValueExpressionParser.yy: At global scope:
ValueExpressionParser.yy:263: error: expected unqualified-id before ‘&’ token
ValueExpressionParser.yy:263: error: expected ‘,’ or ‘...’ before ‘&’ token
ValueExpressionParser.yy:263: error: invalid use of incomplete type ‘struct yy::ValueExpressionParser’
./ValueExpressionDriver.H:16: error: forward declaration of ‘struct yy::ValueExpressionParser’
make: *** [Make/linuxGccDPOpt/ValueExpressionParser.o] Error 1
Could someone explain what might be going wrong? I would be very thankful, if possible could you direct me to some guide that talks about the whole process? I followed the userguide tutorial that talks about how to compile turbfoam. But the above case is far more complex for me to figure out. Thank you.
Prapanj
prapanj is offline   Reply With Quote
Old   March 20, 2009, 05:39
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
At first: is there a reason why you're using a version that is in the section "Ancient history" (http://openfoamwiki.net/index.php/Contrib_funkySetFields#Ancient_history)?
Which version of OpenFOAM are you using? If it is 1.5 go to http://openfoam-extend.svn.sourcefor...ostProcessing/ and get the most recent version by clicking on "Download tarball". For 1.4.1 use http://openfoam-extend.svn.sourcefor...ostProcessing/. For older versions you're on your own. Sorry
Prapanj
I think I remember that one. Newer versions of bison don't like the old grammar-specifications. This is fixed in the above mentioned version (not in the 1.4.1. There you'd best use the generated Files that come with it - see the README)
Bernhard
PS: I will update the Wiki with a link to the tarball-download
gschaider is offline   Reply With Quote
Old   March 22, 2009, 23:30
Default Thank you
Prapanch Nair
Hi Bernard,
Thank you. I had looked at the wrong place for the download. I got the right now. It's up and running.
By the way, Great Tool.
thank you
Prapanj
Old   June 24, 2009, 08:56
ozie
ozie is on a distinguished road
Hello everybody,
I downloaded funkySetField for the OpenFOAM 1.4.1 from the page
http://openfoamwiki.net/index.php/Co...funkySetFields in the directory /utilities/Preprocessing. Than I did wmake. But I had some errors as below;
SOURCE=ValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/ValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/ValueExpressionLexer.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/emre/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/emre/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/emre/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/ValueExpressionLexer.C -o Make/linuxGccDPOpt/ValueExpressionLexer.o
rm: ne peut enlever `Make/linuxGccDPOpt/ValueExpressionLexer.C': Aucun fichier ou répertoire de ce type
/bin/sh: flex: command not found
mv: ne peut évaluer `*.c': Aucun fichier ou répertoire de ce type
g++: Make/linuxGccDPOpt/ValueExpressionLexer.C: Aucun fichier ou répertoire de ce type
g++: no input files
make: *** [Make/linuxGccDPOpt/ValueExpressionLexer.o] Erreur 1
I am new to OpenFOAM, could you help me to resolve my problem?
thank you in advance for your cooperations
Oguz,
ozie is offline   Reply With Quote
Old   June 25, 2009, 08:07
ozie
Hello everybody,
I noticed why such an error occured as above. Because I didn`t take into account to call ./insertGenerated.sh. So I retried to compile funkysetfields..
But this time, I had the error below;
funkySetFields.C:43:26: error: timeSelector.H: Aucun fichier ou répertoire de ce type
funkySetFields.C: In function ‘int main(int, char**)’:
funkySetFields.C:193: error: ‘Foam::timeSelector’ has not been declared
funkySetFields.C:220: error: ‘Foam::timeSelector’ has not been declared
make: *** [Make/linuxGccDPOpt/funkySetFields.o] Erreur 1
So I checked funkySetFields.C. So I noticed that timeSelector.H is needed to run this program. Indeed, this file doesn`t exist among the funkySetFields files therby causing errors...
Does anyone could tell me how to find timeSelector.H, or maybe am I doing something wrong when compiling funkySetField?
oguz,
Old   June 29, 2009, 09:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by ozie View Post
Hello everybody,
timeSelector.H should be found in $FOAM_SRC/OpenFOAM/lnInclude in 1.5. You are using 1.5 aren't you?
Old   July 31, 2009, 10:25
Ramesh Yapalparvi
yapalparvi is on a distinguished road
I downloaded the latest version of FunkySetFields.tar.gz for V 1.5 from the link provided. I extracted the file in /application/utilities/preProcessing. It created a direction FunkySetField..... I went into the directory and tried ./Allwmake . It saus permission denied..... . Any help would be appreciated.
Thanks
yapalparvi is offline   Reply With Quote
Old   August 3, 2009, 04:14
Assistant Moderator
Bernhard Gschaider
Check with "ls -l" whether the executable bits are set for Allwmake (they should be). If not then set them with "chmod a+x Allwmake"
Old   October 14, 2009, 14:58
Steffen Goertz
Ghash is on a distinguished road
Hi
I use OpenFoam v1.6 and downloaded the right version of funkysetfields. I copied everything in the Preprocessing Folder like described above.
Now I tried to run Allwmake and I get a lot of Errors:
It starts with Errors of the type:
/home/Ghash/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../include/c++/4.3.3/x86_64-unknown-linux-gnu/bits/os_defines.h:44:22: error: features.h: Datei oder Verzeichnis nicht gefunden
then it goes on with this Error:
/home/Ghash/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude/cpuTime.H:43:23: error: sys/times.h: Datei oder Verzeichnis nicht gefunden
and then a lot of Errors like this one:
/home/Ghash/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../include/c++/4.3.3/cwchar:72: error: ‘::mbstate_t’ has not been declared
then this:
/home/Ghash/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../include/c++/4.3.3/x86_64-unknown-linux-gnu/bits/gthr-default.h:46: error: ‘pthread_key_t’ does not name a type
and so on.
All in all a lot of Errors, but I still have the hope, that there is just one reason
I'm new to OpenFoam and Linux, so sorry if this is a stupid question. And thank you for your help!!!
Ghash
Ghash is offline   Reply With Quote
Old   October 16, 2009, 05:41
Assistant Moderator
Bernhard Gschaider
Originally Posted by Ghash View Post
Hi
then this:
and so on.
Ghash
Did you compile anything on that machine before? I doubt it. The features.h is part of the glibc-headers-package on my distro. My tip would be to install the gcc from your OS-Vendor (although you use the OF-provided-gcc). This usually pulls in al the necessary dependencies
Bernhard
Old   October 19, 2009, 04:30
Steffen Goertz
This helped, now it works! Thank you for your help.
Greetings
Ghash
Old   January 29, 2010, 01:42
Mohammad Zakerzadeh
moh1367 is on a distinguished road
Sorry!
Is there a version of FunkySetfields for 1.6. version. If yes please get me the link?
Thanks a lot
moh1367 is offline   Reply With Quote
Old   January 29, 2010, 06:00
Assistant Moderator
Bernhard Gschaider
Originally Posted by moh1367 View Post
Sorry!
Thanks a lot
Have a look at
the SVN-link works out of the box. For the tarball-link just substitute 1.5 with 1.6
Bernhard
Old   January 30, 2010, 11:59
Default FunkySetFields Installation
  #14
Mohammad Zakerzadeh
Thanks, but what should I do with these numerous files?
I taught I should have a .tar file!
Old   January 30, 2010, 19:10
Assistant Moderator
Bernhard Gschaider
Compile them? No. Seriously. Which files are you talking about? In any case (getting via svn or Downloading the tarball and untarring) you get the same directory structure and it should be compiled like a regular utility
And you can get one. See http://openfoamwiki.net/index.php/Co...ields#Download (just before section 7.1)
Old   January 31, 2010, 00:25
Mohammad Zakerzadeh
Thanks!
I got it , it works!
Old   February 17, 2010, 12:09
raul
rudy is on a distinguished road
Hi
I use OpenFoam v1.6 and am trying to cpmpile a new utility FunkySetFields. I copied everything in the Preprocessing Folder like described above.
Now I tried to run wmake from applications/utilties/preProcessing/funkySetField and got following error.
Making dependency list for source file ValueExpressionParser.yy
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionParser.yy
Making dependency list for source file ValueExpressionLexer.ll
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionLexer.ll
Making dependency list for source file ValueExpressionDriver.C
could not open file ValueExpressionParser.tab.hh for source file ValueExpressionDriver.C
Making dependency list for source file funkySetFields.C
could not open file ValueExpressionParser.tab.hh for source file funkySetFields.C
SOURCE=ValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/ValueExpressionParser.C Make/linuxGccDPOpt/ValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/ValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/ValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/ValueExpressionParser.C -o Make/linuxGccDPOpt/ValueExpressionParser.o
In file included from Make/linuxGccDPOpt/location.hh:44,
from ValueExpressionParser.tab.hh:65,
from ValueExpressionParser.tab.cc:68:
position.hh: In function ‘bool ve:perator==(const ve:osition&, const ve:osition&)’:
position.hh:136: warning: suggest parentheses around && within ||
ValueExpressionParser.tab.cc:3207: warning: use of old-style cast
SOURCE=ValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/ValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/ValueExpressionLexer.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/rahul/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/ValueExpressionLexer.C -o Make/linuxGccDPOpt/ValueExpressionLexer.o
rm: cannot remove `Make/linuxGccDPOpt/ValueExpressionLexer.C': No such file or directory
/bin/sh: flex: not found
mv: cannot stat `*.c': No such file or directory
g++: Make/linuxGccDPOpt/ValueExpressionLexer.C: No such file or directory
g++: no input files
make: *** [Make/linuxGccDPOpt/ValueExpressionLexer.o] Error 1
can anyone please tell me what i m doing wrong...what i can make out is may be i downloaded an older version(for 1.5) and that may be the source of error but i m not sure...Any suggestions are appreciated...
thanks,
rudy...
rudy is offline   Reply With Quote
Old   February 17, 2010, 13:12
Assistant Moderator
Bernhard Gschaider
Originally Posted by rudy View Post
Hi
<snip>
g++: no input files
thanks,
rudy...
First thing I noticed is the missing flex-command. Install that too on your system (bison&flex usually come in pairs. They're the Starsky&Hutch of computer science)
Bernhard
Old   March 9, 2010, 08:21
G B
Disco_Caine is on a distinguished road
Hi, ive just downloaded funkysetfields and i need to get it running ASAP.
At first i had the funkysetfields folder in a folder called openFOAMwiki outside of the OpenFOAM-1.6.x folder, after reading the posts here i put it in the preprocessing folder.
Now i go step inside the funkySetFields folder and try this:
But it says permission denied.
i tried just compiling with wmake and i get the error that the fellow above gets.
I am really new to this and very lost, so if anyone can help, please
make it very simple and clear. I am total linux-newb, perhaps even
less than a newb.
P.S: i do have another comment about installing openfoam on ubuntu,
this is on another computer.
thanks in advance!
Disco_Caine is offline   Reply With Quote
Old   March 9, 2010, 14:01
G B
I have fixed my own problem, perhaps this is way too obvious for the almighty linux users, but i shall post it anyways, just in case another new guy runs into the same problem.
1) open up your terminal and make sure you are in the funkySetFields folder, (where the insertGenerated.sh is) and type this:
chmod +x insertGenerated.sh
2) then type:
3) then, wmake.
And you are done with funkySetFields
P.S: sorry about the different fonts!
funkysetfields, installation, valueexpressionparser, wmake
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 14:39
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1 ozie OpenFOAM Community Contributions 8 September 8, 2011 11:16
