[swak4Foam] Generating a parabolic Profile with groovyBC
Old   March 26, 2010, 12:29
Default Generating a parabolic Profile with groovyBC
Andreas
erklaerbaer is on a distinguished road
How can i generate a parabolic velocity profile with groovyBC?
The entry in the openfoamwiki isnt really helpful. The example "parabolic inlet condition that pulsates " generates an error and i cant find any "real" documentation. If someone could point me to the solution i would be really grateful.
erklaerbaer is offline   Reply With Quote
Old   March 27, 2010, 06:47
Andreas
I managed to get a parabolic profile with
variables "w=0.00005;m=3;n=2;Umax=1*(m+1)*(n+1)/m/n;c=pos().y-w;d=pos().z-w;a=pow((c/w),2);b=pow((d/w),2);speed=Umax*(1-a)*(1-b);";
valueExpression    "vector (speed, 0, 0)";
in my starting file for U but i have two problems.
pow() does not accecpt non integer values for the exponent like pow(a,1.5) is this a "normal" behaviour?
and
i need some function to get the distance from a point like
distance = pos().z-w now this will result in an negative value if pos().z <w which "should" be positive, i tried abs() but it seems its not implemented and i tried something like sqr(pow(pos().z-w,2)) which doesnt work either.
has anybody an idea?
thanks
Old   March 27, 2010, 09:14
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
and
thanks
Strange, pow() should be able to deal with floating point exponents ...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 29, 2010, 14:31
Assistant Moderator
Bernhard Gschaider
and
thanks
According to the grammar file power should work with any scalar-constant as an exponent. It doesn't work with expressions. So something like pow(p,T) or even pow(p,3./2) are NOT possible. What is the expression that is not working for you and what is the error message?
Bernhard
Old   April 7, 2010, 15:42
Andreas
Sorry for answering so late; I solved the problem another way.
I think (I did and learned a lot inf and of OpenFOAM the last days) I just missused the Expression.
Old   June 4, 2010, 15:18
Default groovyBC
Chrisi1984 is on a distinguished road
Can someone tell me how I can use groovyBC?
I read the article in OpenFoamWiki http://openfoamwiki.net/index.php/Co...rds_of_warning,
but I do not understand this part:
1.2 Pre-requisites
To compile this utility Bison has to be installed. The compilation is known to work with version 2.4.1. It may probably work with older versions. Check with
bison -V
on the command line before trying to compile it and report the version number when reporting a problem.
2 Usage
2.1 Compilation and installation
Just do
wmake libso
in the directory of the sources. The library will be compiled and installed in a place (%FOAM_USER_LIBBIN) where it is usable
I installed bison 2.4.1 like it is written in the install-file:
./configure
make
make install
where do I now have to write "wmake libso"? What means "in the directory of sources"?
Best Regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   June 6, 2010, 03:54
Andreas
Hi Chrisi,
you have to type "wmake libso" in the directory of groovyBC. The directory "make" should be in that directory where to type "wmake libso".
Wenn du wmake eintippst sucht das Skript nach dem Ordner Make und dort nach den Steuerdateien, deswegen musst dein aktuelles Arbeitsverzeichnis Der Ordner sein wo der Ordner "make" drinliegt.
Old   June 6, 2010, 11:59
Thank you,
I tried to do so but, I have a problem in compiling groovyBC. I am using OF 1.6.x.
I have bison (GNU Bison) 2.4.1 and flex 2.5.35.
I copied all the files of groovyBC from here https://openfoam-extend.svn.sourcefo...ries/groovyBC/.
and put it into my run folder. When I compile it I get the following error:
root@chrisilinux:~/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/groovyBC# wmake libso
wmakeLnInclude: linking include files to ./lnInclude
make: *** Keine Regel vorhanden, um das Target »PatchValueExpressionDriver.dep«,
benötigt von »Make/linuxGccDPOpt/dependencies«, zu erstellen. Schluss.
I yet tried compiling with out coomented groovyBCPointPatchFields.C, but it did not help.
Can you help me compilling groovyBC?
Thanks in advance.
Regards
Chrisi
Old   June 6, 2010, 12:54
Andreas
okay ähm.
You ned to install "svn" if it isnt already there.
Then go to a location of your choice, eg run/user_apps or whatever and paste the following line in the console
and hit Enter, svn will then download all files you ned.
After svn did its job there should be a ne folder, go with the shell to the appropirate folder (where there is a subfolder "make") and enter
"wclean" and than "wmake libso". Should work
If there comes an error just post it here.
Currently i have no OpenFOAM installed (or any linux) but i survived installing groovyBC
Old   June 6, 2010, 14:51
Thank you erklaerbaer!!
Vielen Dank!!
Dann kann ich jetzt mal versuchen damit zu arbeiten.
Now I can use groovyBC!!
Regards
Chrisi
Thread Tools
Trackbacks are On
Generating a parabolic profile in gmsh matt.mech.eng Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 February 21, 2016 13:38
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 15:31
[swak4Foam] parabolic velocity profile with fluctuations (groovyBC?) newOFuser OpenFOAM Community Contributions 17 July 15, 2013 17:27
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 08:59
