-   OpenFOAM Community Contributions (https://www.cfd-online.com/Forums/openfoam-community-contributions/)
-   -   [swak4Foam] funkySetFields and OF1.7.0 (https://www.cfd-online.com/Forums/openfoam-community-contributions/77953-funkysetfields-of1-7-0-a.html)
rcastilla July 8, 2010 08:14
Hi, I was using funkySetFields with interFoam in OpenFoam 1.6 without problems. Now, I have upgraded to 1.7.0, and compiled the funkySetFields and it gives the error:
--> FOAM FATAL IO ERROR:
Unknown patchField type constantAlphaContactAngle for patch type wall
Valid patchField types are :
41
advective
buoyantPressure
calculated
cyclic
directMapped
directionMixed
empty
fan
fixedFluxPressure
fixedGradient
fixedInternalValue
fixedPressureCompressibleDensity
fixedValue
freestream
freestreamPressure
inletOutlet
inletOutletTotalTemperature
mixed
oscillatingFixedValue
outletInlet
partialSlip
processor
rotatingTotalPressure
sliced
slip
symmetryPlane
syringePressure
timeVaryingMappedFixedValue
timeVaryingMappedTotalPressure
timeVaryingTotalPressure
timeVaryingUniformFixedValue
timeVaryingUniformInletOutlet
totalPressure
totalTemperature
turbulentInlet
turbulentIntensityKineticEnergyInlet
uniformDensityHydrostaticPressure
uniformFixedValue
waveTransmissive
wedge
zeroGradient
related to the modification of the alpha1 file.
Any idea of wath is wrong?
Robert
gschaider July 8, 2010 09:57
Robert
FSF only "knows" (because it is linked against that) the boundary-conditions in libfiniteVolume.so. The BC you have is application-specific. So it is either implemented in the solver or in another library. In the first case you have bad luck and must temporarily change the BC on the patch to something from that list. In the second case (BC in a library) you can add the library to the libs-list in the controlDict. The library will then be loaded in the beginning and FSF will "know" it
Bernhard
rcastilla July 8, 2010 10:23
Bernhard,
I wanted to use FSF with an interFoam simulation. So, I have put the same includes and libs in the options file in the Make folder than in the interFoam source tree, I have recompiled it, and now it works perfectly.
Thanks so much!
Robert
gschaider July 8, 2010 15:43
An entry of the form
libs ("libmissingLibrary1.so" "libmissingLibrary2.so");
in the controlDict of the case would have had the same effect and you would not have to recompile FSF for every other solver/case
Bernhard
steph79 November 5, 2012 00:56
I've been experiencing the same error when using FSF (in 2.1.1) to initialise a domain containing a constantAlphaContactAngle patch. Does anybody know the specific libraries to include in the controlDict? I know how to work around it, but it would be preferable to have a robust solution.
Thanks.
michielm November 6, 2012 04:33
I think you need this one: libtwoPhaseInterfaceProperties.so
because that is the library where constantAlphaContactAngle is build-in
shri@ January 20, 2017 03:03
Thank you !
I had a similar problem while implementing the 'dynamicAlphaContactAngle' for my case.
For OpenFOAM 3.0.x (with swak4Foam version 0.4.0 ) you need to add
"libtwoPhaseMixture.so" and "libtwoPhaseProperties.so" to controlDict libs section for implementing dynamic contact angle.
I am looking for a way where I can inject droplets (liquid ) in VOF setup (interFoam) after each time step.
It would be great if someone can guide me.
Thank you in advance.
Shridhar
