[swak4Foam] Wave generation with 1.7.x and groovyBC
Old   September 9, 2010, 08:57
Default Wave generation with 1.7.x and groovyBC
Emanuele
nuovodna is on a distinguished road
Hi, i setted up a 2d box with an inlet patch that generates a 1st order Stokes wave using groovyBC. The simulation stop to run (giving floating point exception) after 0.55 sec
This is the case
http://db.tt/Jiicy8A
nuovodna is offline   Reply With Quote
Old   September 9, 2010, 10:14
mikael
keul is on a distinguished road
Hi Emanuele,
I runned your case with some modifications. In the alpha1 file, I changed the inlet condition by a zeroGradient and in the p_rgh file I changed the outlet condition by buyoantPressure. Now your case works fine.
Best regards
keul is offline   Reply With Quote
Old   September 9, 2010, 10:34
Default still crash
Emanuele
Hi mikael, thanks for your fast reply. I made the corrections that you suggested me but it still crashes. Now at t=6.8 sec
Regards
Old   September 9, 2010, 10:42
mikael
When I runned your case, I put the tangentialVelocity in the U file at (0 0 0). Maybe your problem comes from that.
Rgrds
Old   September 9, 2010, 10:50
Emanuele
where do you put tangentialVelocity uniform (0 0 0); ?? On which patch?
Thanks
E
Old   September 9, 2010, 10:55
mikael
In your U file, patch atmosphere, I replace (1 0 0) by (0 0 0)
Old   September 9, 2010, 11:14
Default it works but not like i want
Emanuele
Changing the value of tangentialVelocity it doesnt crash anymore. But the free surface prediction is wrong.
This is the graph of computed free surface (red) against analytical solution (green) at t=20 sec
Old   September 9, 2010, 11:32
mikael
Maybe you could try with the program I use. It generates regular waves with the deep water hypothesis. You could compile the waveBC folder with wmake. I put a floating body tutorial.
Old   September 9, 2010, 11:40
Default waveBC condition
Emanuele
I compiled waveBC yesterday but in the tutorial folder alpha1 file is missing. I grabbed it from shipHydrodynamicIG svn. Can you attach an example of waveBC on a case??
Thanks
Regards
E
mikael
Sorry the file was to big.
Old   September 9, 2010, 11:44
mikael
For the alpha1 file, you could use the same file as your case with zeroGradient on all patches except eventually atmosphere with an inletOutlet condition.
Good luck
Default Allrun error
  #12
Emanuele
I launched Allrun but the alpha1.org~ file is missing
cp: cannot stat `0/alpha1.org~': No such file or directory
Edit: Ok i ll try. Thanks!
Edit: It works. Now i m going to make some test
Old   September 9, 2010, 12:06
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
First of all, you have defined omega (w) differently in the alpha1.ORG and the U files in your input groovy file. This is most definitely one error in the input, which can result in the strange profiles in your post #7.
However, be aware, that linear wave theory will not yield the analytical solution in shallow water as the linear theory does not fulfill the boundary conditions for the non-linear wave problem at the inlet.
I am utterly surprised that the waveBC still exists out there, it has changed a bit since those years back, however I can still find my old comments in Danish I hope it works for you.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   September 14, 2010, 05:02
Default Wave
  #14
Emanuele
Hi Niels, thanks for your answer. I re-setted the case using an water depth >= Wavelength/2 but the results are still wrong (i'm using groovyBC). Do you know another system available in OF to generate waves?
Thanks in advance
Regards
Emanuele
Old   September 14, 2010, 05:31
ngj
Hi Emanuele
Yes, I have a different system, however currently I am working on a journal article, and the source will not be released prior to publication/acceptance of the article. I made a presentation of the framework at the Gothenburg workshop, see [1].
I have been working on a specific validation case for a long time without succes, so I will not be able to give a time line for the release.
Good luck,
Niels
[1]: http://web.student.chalmers.se/group...SlidesOFW5.pdf
groovybc, interfoam, wave, wavebc, waves
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
Wave generation inlet using interFoam Katzenpaul OpenFOAM Running, Solving & CFD 2 February 6, 2013 09:28
[swak4Foam] GroovyBC for 2D wave flume! Hisham OpenFOAM Community Contributions 13 January 20, 2012 05:04
[swak4Foam] groovyBC in 1.7.x ??? fisch OpenFOAM Community Contributions 1 June 7, 2011 08:58
Wrong wave generation nuovodna OpenFOAM 2 August 9, 2010 10:53
