-   OpenFOAM Community Contributions (https://www.cfd-online.com/Forums/openfoam-community-contributions/)
-   -   [swak4Foam] Problem with funkySetFields: How to set field on patch? (https://www.cfd-online.com/Forums/openfoam-community-contributions/85660-problem-funkysetfields-how-set-field-patch.html)
DanielPT March 3, 2011 13:53
I have some problems with funkySetFields. I want to set a fully developed velocity profile on my inlet.
But after running funkySetFields -time 0 the file 0/U contains a filed for the whole mesh and my entry for Inlet is even the entry before using FSF.
My funkySetFieldsDict:
surface
field U;
expression.....
valuePatches (inlet);
keepPatches 0;
Thanks and regards
Daniel
gschaider March 3, 2011 17:44
surface
field U;
expression.....
keepPatches 0;
Thanks and regards
Daniel
Hmmm. You tried to do it by hand like it is described in http://openfoamwiki.net/index.php/Co...t-Room_Example (BTW: of course you'll need a second expression to clear the internal field). What type is inlet. I think it has to be a fixedValue-patch if FSF should be able to set values there.
Bernhard
PS: for just setting patch-values there is a utility funkySetBoundaryFields in the swak4Foam-suite.
alfa_8C May 5, 2011 05:49
...referring to the last post:
http://www.cfd-online.com/Forums/ope...tml#post306326
Ok, Berhard. Now it works really well!! Thank you.
But there is one further I don't understand so far. If I apply the following expression:
"faceAverage(fpos().z <= surf(3.) ? surf(1.0) : surf(0.))"
the red part determines at which height the free surface will be set - in this case at 3m. This is ok for simply horizontal initial free surfaces.
In the case I want to apply an inital free surface that varies over lenght i.e. along a slope (pic illustrates the problem), I have to insert a linear function f(z)=m*x+n. But the expression doesn't accept this:
"faceAverage(fpos().z <= surf(-m*pos().x+n) ? surf(1.0) : surf(0.))"
Whereas the condition accepts it without any problem.
Is there any solution for this problem?
gschaider May 5, 2011 11:41
What do you mean with "Whereas the condition accepts it without any problem"? In real life of course you use values for m and n?
What is the error message? Without it I can't do much and I don't have the time to test the expressions "by hand"
BTW: If thing the better variant (I'm doing this from memory the syntax might be slightly different) would be in my opinion "<= surf(42.)+fpos().x*surf(13.)" with the values 13 and 42 for m and n
alfa_8C May 6, 2011 09:45
...the problem is solved. Your hint....
led me to the solution. It was just a synthax error.
Thank you Bernhard!!
Best, Toni
