How to solve alphaEqn using PythonFlu?
Hi foamers,
I am writing twoliquidMixingFoam solver in python using PythonFlu. I have done everything except alphaEqn.H { fvScalarMatrix alpha1Eqn ( fvm::ddt(alpha1) + fvm::div(phi, alpha1) - fvm::laplacian ( Dab + alphatab*turbulence->nut(), alpha1, "laplacian(Dab,alpha1)" ) ); alpha1Eqn.solve(); rhoPhi = alpha1Eqn.flux()*(rho1 - rho2) + phi*rho2; rho = alpha1*rho1 + (scalar(1) - alpha1)*rho2; Info<< "Phase 1 volume fraction = " << alpha1.weightedAverage(mesh.V()).value() << " Min(alpha1) = " << min(alpha1).value() << " Max(alpha1) = " << max(alpha1).value() << endl; } How can I solve this in PythonFlu? In particularly I have doubt in turbulence->nut(). I have tried this. See below code def alphaEqn( mesh, phi, alpha1, rhoPhi, rho1, rho2, interface): from Foam import fvm alpha1Eqn = fvm.ddt(alpha1) + fvm.div(phi, alpha1) - fvm.laplacian( Dab + alphatab*turbulence.nut(), alpha1, "laplacian(Dab,alpha1)") alpha1Eqn.solve() rhoPhi.ext_assign(alpha1Eqn.flux()*(rho1 - rho2) + phi*rho2) rho.ext_assign(alpha1*rho1 + (1.0 - alpha1)*rho2) from Foam.OpenFOAM import ext_Info, nl ext_Info() << "Phase1 volume fraction = " << alpha1.weightedAverage( mesh.V() ).value() \ << " Min(alpha1) = " << alpha1.ext_min().value() \ << " Max(alpha1) = " << alpha1.ext_max().value() << nl pass It shows error on turbulence.nut(). Thanks in advance. |
Hi Dhasthagheer,
To speed up this investigation I suggest you upload your pythonFlu implementation of "twoLiquidMixingFoam" and your use-case to check on. Best regards, Alexey |
1 Attachment(s)
I have attached my case files and my python file. I am getting following error
Traceback (most recent call last): File "twoLiquidMixingFoam.py", line 303, in <module> os._exit( main_standalone( len( argv ), argv ) ) File "twoLiquidMixingFoam.py", line 57, in main_standalone alphaEqn( mesh, phi, alpha1, rhoPhi, rho1, rho2, interface ) File "twoLiquidMixingFoam.py", line 87, in alphaEqn alpha1Eqn = fvm.ddt(alpha1) + fvm.div(phi, alpha1) - fvm.laplacian( Dab + alphatab*turbulence.ext_nut(), alpha1, "laplacian(Dab,alpha1") File "/usr/local/lib/python2.6/dist-packages/Foam/OpenFOAM/OpenFOAM_.py", line 3462, in __mul__ return _OpenFOAM_.dimensionedScalar___mul__(self, *args) TypeError: in method 'dimensionedScalar___mul__', argument 2 of type 'Foam::dimensioned< Foam::scalar > const &' The alphaEqn.H header file contains { fvScalarMatrix alpha1Eqn ( fvm::ddt(alpha1) + fvm::div(phi, alpha1) - fvm::laplacian ( Dab + alphatab*turbulence->nut(), alpha1, "laplacian(Dab,alpha1)" ) ); alpha1Eqn.solve(); rhoPhi = alpha1Eqn.flux()*(rho1 - rho2) + phi*rho2; rho = alpha1*rho1 + (scalar(1) - alpha1)*rho2; Info<< "Phase 1 volume fraction = " << alpha1.weightedAverage(mesh.V()).value() << " Min(alpha1) = " << min(alpha1).value() << " Max(alpha1) = " << max(alpha1).value() << endl; } So I tried like following def alphaEqn( mesh, phi, alpha1, rhoPhi, rho1, rho2, interface): from Foam.finiteVolume import fvScalarMatrix from Foam import fvm alpha1Eqn = fvm.ddt(alpha1) + fvm.div(phi, alpha1) - fvm.laplacian( Dab + alphatab*turbulence.ext_nut(), alpha1, "laplacian(Dab,alpha1") alpha1Eqn.solve() rhoPhi.ext_assign(alpha1Eqn.flux()*(rho1 - rho2) + phi*rho2) rho.ext_assign(alpha1*rho1 + (1.0 - alpha1)*rho2) from Foam.OpenFOAM import ext_Info, nl ext_Info() << "Phase1 volume fraction = " << alpha1.weightedAverage( mesh.V() ).value() \ << " Min(alpha1) = " << alpha1.ext_min().value() \ << " Max(alpha1) = " << alpha1.ext_max().value() << nl pass |
Thank you Dhasthagheer.
If we swap the two arguments in the target expression (I mean, "alphatab" and "turbulence.ext_nut()") like "turbulence.ext_nut() * alphatab", will it still work for you? By the way, could you precise what version of OpenFOAM do you use? I have failed to run "blockMesh" for OpenFOAM-1.7.1-deb utility on the attached case, see Code:
/*---------------------------------------------------------------------------*\ Alexey |
I am using Openfoam 1.7.1 .
blockMesh working fine for me in this case $ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-4bbf33160caf Exec : blockMesh Date : May 15 2011 Time : 22:53:09 Host : Dhastha PID : 3950 Case : /home/dhastha/New_PythonFlu/tutorial/twoLiquidMixingFoam/twoStream nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/dhastha/New_PythonFlu/tutorial/twoLiquidMixingFoam/twoStream/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576 Found 4 undefined faces in mesh; adding to default patch. Check block mesh topology Basic statistics Number of internal faces : 1 Number of boundary faces : 10 Number of defined boundary faces : 10 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points with scale 0.01 Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Writing polyMesh End |
Hi
I swapped the two arguments in the target expression. see the changes alpha1Eqn = fvm.ddt(alpha1) + fvm.div(phi, alpha1) - fvm.laplacian( Dab + turbulence.ext_nut()*alphatab, alpha1, "laplacian(Dab,alpha1") It shows following error Code:
Traceback (most recent call last): |
The initial problem with calculation of "alphatab * turbulence.ext_nut()" expression can be solved by the following modifications :
This actually solves the initial problem. After this next appears, the following specialization of "laplacian" function is not wrapped yet : tmp< scalarMatrix > laplacian( const tmp< volScalarField >& tgamma, volScalarField& vf, const word& name )So, we got stack on the missed "laplacian" function :( P.S. Dhastha, thank you very much for your patience. pythonFlu is still on his way to complete wrapping. And this kind of "lacked" functionality is possible. The next pythonFlu release (which is actually planned in 2 weeks) will solve all the mentioned issues ...Keep in touch, Alexey |
1 Attachment(s)
In the attachment you can find as the new version of pythonFlu based solver, as well, as modified use-case to test it (there were some important differences with the referenced one). So, if you are interested, you could find out the exact reason of the failure by comparison ours implementation with your. If you made your modifications with some deep meaning, you could also use our implementation as a referenced point for your variation. Good luck, Alexey |
