[swak4Foam] Using swak4Foam in setFieldsDict
Old   October 17, 2014, 01:11
Default Using swak4Foam in setFieldsDict
RAHUL JOSHI
RAUL is on a distinguished road
How to use swak4Foam in openfoam 2.3.0. Also I need to set an expression for velocity in regions patch in setFieldsDict. Is it possible using swak4Foam ?
RAUL is offline   Reply With Quote
Old   October 17, 2014, 06:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by RAUL View Post
You've got to install and compile it before you can use it: http://openfoamwiki.net/index.php/Contrib/swak4Foam
There comes a command funkySetFields with it that does that (setting fields by expression)
An introduction to using it would for instance be http://openfoamwiki.net/images/7/7a/...icTraining.pdf
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 17, 2014, 09:57
RAHUL JOSHI
Thank you Bernhard.
Cheers,
RAUL
of230, setfieldsdict, swak4foam
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
InterDyMFoam+simpleFunctionObject Elham OpenFOAM Running, Solving & CFD 5 July 10, 2017 11:59
[swak4Foam] and twoPhaseEulerFoam mnikku OpenFOAM Community Contributions 1 February 19, 2016 05:21
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
