[OpenFOAM.com] bashrc file doesn't source, windows |
April 20, 2018, 05:01 |
Rep Power: 8 |
Hi community
I've installed openfoam on windows and my problem now is that I can't source the bash file for some reason. It is at the right place, but the terminal says that it can't find the file. Has someone an idea what the problem is? (my pc is a laptop, the gigabyte p57wv6, i have windows 10 on it, bash worked fine so far) A picture of what the terminal say's: (the first image with the ^C: https://preview.ibb.co/hn8a6n/2.jpg ) Last edited by Flexflix; April 20, 2018 at 07:37. Reason: better understandable image |
April 20, 2018, 06:02 |
Uwe Pilz
Rep Power: 15 |
You have a ^C appended to your command. I don't know where it came form but the error message indicates it.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 20, 2018, 07:26 |
Rep Power: 8 |
@piu58 thank you for your reply
the ^C appeares because I tieped it at the end of my first command. I tried a commed I have seen and the terminal said if I didn't miss understand that the bashrc file can't be found at that location. But as seen in the next line with the list command, the fiel exstist. As also seen with the third command when I listed all files in OpenFOAM/OpenFOAM-v1712/etc/ Now I wonder why the terminal at the beginning and with the ^C command says, that bashrc can't be found in that location and what I can do to solve the problem. |
April 20, 2018, 16:36 |
Solved
Rep Power: 8 |
Ok so the riddle is solved, I just had missspelled the path.
bash on ubuntu on windows, bashrc, source |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
