[OpenFOAM.com] v1612+ pre-compiled binaries Mac Os |
May 23, 2018, 04:50 |
Guiem
Hi all,
I would like to install in my Mac computer the version 1612+ of openFOAM, as that is the one installed on the HPC facilities I need to use. However, I cannot find anywhere the pre-compiled binaries of this version for Mac, in order to install program through the Docker, as recommended by openFOAM. Does somebody know where I can find these files? Can somebody provide the to me? Thanks a lot in advance. |
July 10, 2018, 03:08 |
matej forman
Rep Power: 17 |
Edit your instalMacOpenFOAM file and change the name of the imageName variable to your favorite version of OpenFOAM to download the appropriate image. The docker images are uploaded to the docker central image site, so you should be able to found the correct name in the intuitive name change does not work. |
mac os, openfoam, openfoam 1612 |
[ICEM] Pre inlfation layer settings | Jeroenm | ANSYS Meshing & Geometry | 0 | September 29, 2016 03:22 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
