OpenFOAM Debugging in kDBg
Hi all,
I was trying to debugg the OpenFOAM code in KDBg. it is similar to GDB, I have compiled the OpenFoam Debug version by making change in bashrc file. And then I have the linuxGccDPDebug folder which has all executables present . If I try to run the gdb it is working properly , but while running the KDBg I am getting the error: /home/sandip/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPDebug/bin/icoFoam: error while loading shared libraries: libfiniteVolume.so cannot open shared object file : No such file or directory . Actually this libfiniteVolume.so file is present in linuxGccDPDebug/lib folder. But still this error is comeing. Anybody is having any idea about how to resolve this issue, previously I was able to debug the OpenFOAM in KDBg. Please see the attached bashrc file for more information. with regards. |
Greetings Sandip,
You're having the same problem that others have had with Eclipse IDE. A few solutions have been posted by me in the following posts:
Best regards, Bruno |
Default OpenFOAM Debugging in kDBg
Thanks for the reply
If KDBg is launched through the terminal then it is working fine. But not if launched directly Applications->Programming Tools->KDBg with regards. |
