installtion error for OF210 source pack
Old   May 14, 2012, 15:44
Default installtion error for OF210 source pack
Nitin Suryawanshi
suryawanshi_nitin is on a distinguished road
hi
i m facing issue in installing of210 source pack. for envoirmental settings, i have added the lines at end of the .bashrc file as follow
alias of201='source /opt/openfoam201/etc/bashrc'
alias of210='source $HOME/openFOAM/OpenFOAM-2.1.0/etc/bashrc'
but when i m running ./Allwmake through i m getting following error msg
administrator@ubuntu:~/openFOAM/OpenFOAM-2.1.0$ ./Allwmake
./Allwmake: 9: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
My machine is lenova 32 bit, allready OF201 debian pack is there in machine working properly,
plz help me on this thanks in advance
Nitin
suryawanshi_nitin is offline   Reply With Quote
Old   May 14, 2012, 16:47
Retired Super Moderator
Bruno Santos
Greetings Nitin,
I was going to say that you had forgotten to run "of210" in the terminal, but now I noticed that you missed an important letter:
  • You have this:
  • When you should have this:
    alias of210='source $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc'
It's "OpenFOAM", not "openFOAM"
Best regards,
Bruno
Old   May 16, 2012, 01:02
Nitin Suryawanshi
Dear Bruno thanks for your reply, as per your suggestions i have changed the folder name from openFOAM to OpenFOAM, also accordingly changed path in .bashrc file as below
but when i m getting for compilation of for gettting source code to work follwing msg is shown in terminal
administrator@ubuntu:~/OpenFOAM/OpenFOAM-2.1.0$ ./Allwmake
kindly waiting for reply.. thanks in advance
Old   May 16, 2012, 16:24
Bruno Santos
Hi Nitin,
  1. Start a new terminal.
  2. Run:
    echo $WM_PROJECT_DIR
    It shouldn't output anything. If it does output anything, then your .bashrc file is contaminated with an OpenFOAM related line that isn't using "alias" at the beginning of that line.
  3. If all OK, run:
    of210
  4. Run:
    cd $WM_PROJECT_DIR
  5. Where did you land? If you landed in the correct folder, now you can run Allwmake.
Here is some more reading material on this subject: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
Old   May 17, 2012, 06:42
Nitin Suryawanshi
Hi Bruno,
As you said i started with new terminal and with correct working directory that is the folder in which OpenFoam2.1.0 is extracted and now i m able to compile source code by using ./Allwmake.
Thanks alot Bruno its working now with your valuable suggestions...
Nitin
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
