Error trying to install 2.1.x on Ubuntu 12.04 |
June 25, 2012, 22:46 |
Rep Power: 13 |
Hi everyone. I've gotten stuck at the part where I'm supposed to source the bashrc. When I input
source /opt/OpenFOAM-2.1.x/etc/bashrc Code:
-su: /root/OpenFOAM/OpenFOAM-2.1.x/<Stuff>: No such file or directory All told there are 11 files or directories not found. Any ideas what I'm doing wrong? Thanks. |
June 26, 2012, 02:34 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Tetragramm,
Building OpenFOAM (or almost anything else) as root is not a good idea, because one wrong key push and you might damage your OS installation... and with luck, spend an additional 30 or more minutes reinstalling it. If you still want to take that risk, then you should have read the whole installation instructions page - http://www.openfoam.org/download/git.php - more specifically section "Setting environment variables for alternative locations": Quote:
Best regards, Bruno
June 26, 2012, 07:21 |
Rep Power: 13 |
That was it, thanks. I'm not too worried about messing up. It's running on a VM with a restore image ready just before I started the install process. Also, because I'm using this to set up a LiveCD, I don't have a choice but to run in root, because that's how UCK works.
I'm being very careful not to make any typos, the problem comes when I don't understand something, or worse, misunderstand it. In this case, I thought that was going to be an output directory and had it set somewhere that didn't exist. Thanks for you help. |
Errors while installing openfoam on ubuntu 12.04 AND 11.10 | fshak92 | OpenFOAM Installation | 27 | May 1, 2021 12:10 |
[foam-extend.org] OpenFOAM-1.6-ext on Ubuntu 12.04 install errors | benk | OpenFOAM Installation | 37 | August 8, 2016 11:48 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 04:56 |
how to install openfoam on ubuntu 1.4 ? | seyedashraf | OpenFOAM Installation | 8 | August 23, 2011 05:50 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
