[OpenFOAM.org] How to build Open FOAM with Intel compilers...?
Old   September 16, 2012, 14:26
Default How to build Open FOAM with Intel compilers...?
Rui Alexandre Trigo Ribeiro Pereira
ed_teller is on a distinguished road
Hi
I have installed intel parallel studio in My Ubuntu 12.04, and I am trying to build OF-2.1.1 using intel.
I untarred Third-party, as well as OpenFoam-2.1.1
I set the environment in /etc/bashrc after changing the default compilers to intel.
I cd to third party, and run ./Allwmake
compilation occurs without incidents, then i cd to OpenFOAM-2.1.1, and run ./Allwmake again.
The libraries build ok, but some of the solvers and utilities do not build, the typical message involves something about libpstream.so :
 icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -xSSE3 -O2 -no-prec-div  -DNoRepository -IphaseModel/lnInclude -ImultiphaseSystem/lnInclude -ImultiphaseFixedFluxPressure -IinterfacialModels/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/interfaceProperties/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/singlePhaseTransportModel -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LES/LESModel -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/alex/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64IccDPOpt/multiphaseEulerFoam.o -L/home/alex/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib \
             -lmultiphaseSystem -lcompressibleMultiPhaseModel -linterfaceProperties -lincompressibleTransportModels -lcompressibleMultiphaseEulerianInterfacialModels -lincompressibleLESModels -lfiniteVolume -lOpenFOAM -ldl   -L/lib -lm -o /home/alex/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/multiphaseEulerFoam
ld: Make/linux64IccDPOpt/multiphaseEulerFoam.o: undefined reference to symbol '_ZN4Foam14incompressible15turbulenceModel8typeNameE'
ld: note: '_ZN4Foam14incompressible15turbulenceModel8typeNameE' is defined in DSO /home/alex/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib/libincompressibleTurbulenceModel.so so try adding it to the linker command line
/home/alex/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/lib/libincompressibleTurbulenceModel.so: could not read symbols: Invalid operation
make[2]: *** [/home/alex/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64IccDPOpt/bin/multiphaseEulerFoam] Error 1
make[2]: Leaving directory `/home/alex/OpenFOAM/OpenFOAM-2.1.1/applications/solvers/multiphase/multiphaseEulerFoam'
make[1]: *** [multiphaseEulerFoam] Error 2
Is there any tutorial detailing how to build OpenFOAM in Ubuntu 12.04 using Intel..?
I am using Intel parallel_studio_xe_2011...
Best regards
Alex
ed_teller is offline   Reply With Quote
Old   September 18, 2012, 15:46
Retired Super Moderator
Bruno Santos
Greetings Alex,
You better try with the latest 2.1.x, because some tweaks for ICC have been done after 2.1.1 was released.
Well... apparently only this was done for it: https://github.com/OpenFOAM/OpenFOAM...08190dc7c05e66 - so maybe you can still use 2.1.1, but apply those changes manually!
As for specific instructions on using Icc... not that I'm aware of, but you are already in the right track! The change from that commit should do the final trick!
Best regards,
Bruno
Old   September 20, 2012, 12:35
Hi Wyldckat
I have built it already
Thanks for the hint
BRGDS
Alex
Old   October 8, 2012, 10:08
Illya Shevchuk
linch is on a distinguished road
Hi Bruno,
me again , this time trying to cmpile OF 2.1.x with icc. I've got some errors directly at the beginning of the ThirdParty build:
icc -O3 -no-prec-div -fPIC lex.yy.c -o /home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/wmake/platforms/linux64Icc/wmkdep
icpc -std=c++0x -wd327,654,819,1125,1476,1505,1572 -xSSE3 -O2 -no-prec-div -DNoRepository -fPIC \
wmkdepend.cpp wmkdependParser.cpp wmkdependScanner.cpp \
-o /home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/wmake/platforms/linux64Icc/wmkdepend
/usr/include/c++/4.3.2/type_traits(82): error: expected a ">"
struct is_rvalue_reference<_Tp&&>
/usr/include/c++/4.3.2/type_traits(106): error: expected a ">"
struct remove_reference<_Tp&&>
/usr/include/c++/4.3.2/type_traits(136): catastrophic error: rvalue references not yet implemented
{ typedef _Tp&& type; };
compilation aborted for wmkdepend.cpp (code 4)
compilation aborted for wmkdependParser.cpp (code 4)
compilation aborted for wmkdependScanner.cpp (code 4)
make: *** [/home/shevchuk/OpenFOAM/OpenFOAM-2.1.x/wmake/platforms/linux64Icc/wmkdepend] Error 4
Do you have any idea, what does it mean?
The rest of the TP-compilation seems to be ok.
Best regards,
Illya
P.S. building OF causes lots of exactly same "catastrophic errors"
linch is offline   Reply With Quote
Old   October 8, 2012, 17:05
Bruno Santos
Hi Illya,
very little information you're giving me
I'll need to know which version of Icc you're using and which Linux Distribution you're using.
I ask this because with each new Icc version, the required list of options can change and because Icc depends very much on the Gcc version that is installed in the system!
Best regards,
Bruno
Old   October 9, 2012, 06:36
Illya Shevchuk
Hi Bruno,
sorry, here it comes. Icc:
icc (ICC) 11.1 20100806
Gcc:
gcc (Debian 4.3.2-1.1) 4.3.2
Linux:
Linux version 2.6.26-2-amd64 (Debian 2.6.26-26lenny3) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch
Distributor ID: Debian
Description: Debian GNU/Linux 5.0.8 (lenny)
Release: 5.0.8
Codename: lenny
Best regards,
Illya
Old   October 10, 2012, 17:33
Bruno Santos
Hi Illya,
OK, I haven't tested this yet, but the idea is this:
  1. First of all, roughly follow the instructions provided here: http://openfoamwiki.net/index.php/In...tu#Ubuntu_8.04
    Adapt where necessary to use 2.1.x instead of 2.1.1.
  2. After you've built everything with success by using Gcc 4.5.2, as instructed on that wiki page section, to make sure everything works as intended... you'll then need to do the following hacks:
    1. Edit the file "$HOME/.bashrc", find the line that says "WM_COMPILER=Gcc45" and replace it with "WM_COMPILER=Icc".
    2. Edit the file "$WM_PROJECT_DIR/etc/config/settings.sh" and find the line that says:
      Gcc45 | Gcc45++0x)
      And replace it with:
      Gcc45 | Gcc45++0x | Icc)
    3. Start a new terminal and build OpenFOAM, simply by running Allwmake once again... once and/or twice, as indicated on the step #10 from the wiki page section.
Best regards,
Bruno
Old   November 30, 2016, 00:51
Default suggestion
rahulksoni's Avatar
Rahul Kumar Soni
rahulksoni is on a distinguished road
Send a message via Skype™ to rahulksoni
The issue can probably be resolved by adding -U__GXX_EXPERIMENTAL_CXX0X__ switch.
According to your configuration locate the appropriate directory in $WM_PROJECT_DIR/wmake/rules/
Edit the c++ named files and append the key so it looks like below:
c++FLAGS    = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -U__GXX_EXPERIMENTAL_CXX0X__
Alternatively see http://www.cfd-online.com/Forums/ope...tml#post627523
rahulksoni is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
