October 15, 2012, 09:19 |
Installation problem on Ubuntu
Mattia
Rep Power: 13 |
Hello, I'm trying to install OpenFoam211 on my Ubuntu. I install it and paraFoam correctly, but at the end of installation process of OpenFoam appear this:
** To use OpenFOAM please add ** ** . /opt/openfoam201/etc/bashrc ** ** To your ~/.bashrc I run the command: gedit /.bashrc and in this file I add the line ". /opt/openfoam211/etc/bashrc" and save it. But when I try to use blockMesh or paraFoam appear that it doesn't find blockMesh (or paraFoam) command. Do you know why? Thanks. Best Regards. Mattia |
October 15, 2012, 10:00 |
Rep Power: 14 |
Have you sourced your bashrc after editing it? -- Simply open a new terminal and try any openfoam command (icoFoam or blockMesh etc.)
If it doesn't work: Is your OpenFOAM installed in the /opt directory or somewhere else? These are the two most common problems. |
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 | Wley | OpenFOAM Installation | 2 | September 28, 2012 06:06 |
HP Elite i7 64bit machine installation problem | ahlo7 | OpenFOAM Installation | 1 | March 1, 2011 17:36 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
[OpenFOAM] Problem with parafoam on ubuntu 9.10 machine | nabeels | ParaView | 0 | December 25, 2009 23:12 |
OpenFOAM Installation Ubuntu 9.04 Problems | Sumontro | OpenFOAM Installation | 8 | July 21, 2009 21:40 |
