Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686
Like Tree1Likes
  • 1 Post By Sbr_CFD
Old   May 20, 2013, 02:24
Default Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686
Angus Hutchison
AHutchison is on a distinguished road
Hey everyone,
I'm a complete beginner with Ubuntu having always been a windows user, but I require OpenFOAM for my thesis.
I'm having trouble with the installation of OpenFOAM 2.2.0 in Ubuntu 12.10 using the i686 architecture.
I have tried both Deb and Source pack installations but I cant get either to work.
I have tried installing by following the steps in this link http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu
but there is no 3rd step for i686.
I would like to know:
what is the difference between deb pack and source pack installation?
Which one do I use?
How to install OpenFOAM 2.2.0 for ubuntu 12.10 using i686
Much appreciated, please remember I am completely new to this!
AHutchison is offline   Reply With Quote
Old   May 20, 2013, 17:14
Retired Super Moderator
Bruno Santos
Greetings Angus,
Sorry, my fault, I have a force of habit of writing i386 instead of i686. Nowadays it's almost all the same. Nonetheless, I've updated the wiki page to avoid confusion.
Which one do I use?
Well, the Deb pack is a install-n-play solution for installing OpenFOAM. It meets most of the needs of any OpenFOAM user.
Building from source gives the ability to build on any Linux Distribution, as well as having more control on how things are built. It also makes it easier to modify the source code and build it again.
As I wrote in the beginning, you can continue to follow the instructions for i386/i686.
Or you can give some more information on what happened when you tried to install the Deb pack version.
Best regards,
Bruno
Old   May 21, 2013, 19:21
Amir
Amir1 is on a distinguished road
Guys,
Can you help me how I can install UBUNTO and OPEN FOAM?
Thanks,
Amir
Amir1 is offline   Reply With Quote
Old   May 21, 2013, 22:44
Angus Hutchison
Originally Posted by wyldckat View Post
Greetings Angus,
Best regards,
Bruno
Here is what i get trying to install the Deb pack version:
Step 1 -
ubuntu@ubuntu:~$ VERS=$(lsb_release -cs)
ubuntu@ubuntu:~$ sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list"
Step 2 -
ubuntu@ubuntu:~$ sudo apt-get update
Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal InRelease
Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/main Translation-en_US
Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/restricted Translation-en_US
Ign http://security.ubuntu.com quantal-security InRelease
Ign http://archive.ubuntu.com quantal InRelease
Ign http://www.openfoam.org quantal InRelease
Ign http://archive.ubuntu.com quantal-updates InRelease
Hit http://security.ubuntu.com quantal-security Release.gpg
Ign http://www.openfoam.org quantal Release.gpg
Hit http://archive.ubuntu.com quantal Release.gpg
Get:1 http://archive.ubuntu.com quantal-updates Release.gpg [933 B]
Hit http://security.ubuntu.com quantal-security/main i386 Packages
Ign http://www.openfoam.org quantal/main i386 Packages/DiffIndex
Get:2 http://archive.ubuntu.com quantal-updates Release [49.6 kB]
Hit http://security.ubuntu.com quantal-security/restricted i386 Packages
Hit http://security.ubuntu.com quantal-security/main Translation-en
Hit http://archive.ubuntu.com quantal/main i386 Packages
Hit http://archive.ubuntu.com quantal/restricted i386 Packages
Hit http://security.ubuntu.com quantal-security/restricted Translation-en
Hit http://archive.ubuntu.com quantal/main Translation-en
Hit http://archive.ubuntu.com quantal/restricted Translation-en
Get:3 http://archive.ubuntu.com quantal-updates/main i386 Packages [235 kB]
Ign http://security.ubuntu.com quantal-security/main Translation-en_US
Ign http://security.ubuntu.com quantal-security/restricted Translation-en_US
Hit http://www.openfoam.org quantal/main i386 Packages
Ign http://www.openfoam.org quantal/main Translation-en_US
Get:4 http://archive.ubuntu.com quantal-updates/restricted i386 Packages [4,841 B]
Hit http://archive.ubuntu.com quantal-updates/main Translation-en
Hit http://archive.ubuntu.com quantal-updates/restricted Translation-en
Ign http://archive.ubuntu.com quantal/main Translation-en_US
Ign http://archive.ubuntu.com quantal/restricted Translation-en_US
Ign http://archive.ubuntu.com quantal-updates/main Translation-en_US
Ign http://archive.ubuntu.com quantal-updates/restricted Translation-en_US
Fetched 291 kB in 12s (24.0 kB/s)
Reading package lists... Done
Step 3 -
ubuntu@ubuntu:~$ sudo apt-get install openfoam220
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
openfoam220 : Depends: csh but it is not installable
Depends: libopenmpi1.3 but it is not installable
Depends: libptscotch-5.1 but it is not installable
Depends: libscotch-5.1 but it is not installable
Depends: libscotch-dev but it is not installable
Depends: libopenmpi-dev but it is not installable
Depends: openmpi-bin but it is not installable
Recommends: libptscotch-dev but it is not installable
E: Unable to correct problems, you have held broken packages.
Which is where i think things are going wrong (step 3)
Old   May 22, 2013, 18:40
Bruno Santos
Hi Angus,
The "universe" repository isn't turned on. For more information on how to turn it on: http://askubuntu.com/questions/78613...e-command-line
After turning it back on, don't forget to do step #2 once again!
Best regards,
Bruno
Old   May 22, 2013, 19:53
Angus Hutchison
Hi Bruno,
Everything seems to be installing quite nicely now, thank you very much! You're probably my favourite person at the moment!
Gus
Old   June 4, 2013, 12:11
Unhappy
SBR
Sbr_CFD is on a distinguished road
My problem in installing the OpenFOAM was solved.
Best Regards
wyldckat likes this.
Sbr_CFD is offline   Reply With Quote
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 11:43
OF-1.6-ext: compiling fails on ubuntu 12.10 A.Wendy OpenFOAM Installation 1 March 22, 2013 06:47
Ubuntu 12.10 64bit: To compile or not? CrazyFatDude OpenFOAM Installation 2 January 14, 2013 04:18
Installing OpenFOAM 2.1 and enGrid aerospain OpenFOAM Installation 7 April 1, 2012 05:19
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
